The angle of line
  • Thread starter KrazyFire
KrazyFire
The angle of the line (x+ SquaredRoot of 3y=12 makes with the positive direction of the x- axis is?
y=mx+c
Make x=0 or y=0
but dont get what to do with it :/...
Answers and Replies
berkeman
Mentor
63,222
14,150
y=mx+c
Make x=0 or y=0
Welcome to the PF. Is this your equation?
[tex]x + \sqrt{3y} = 12[/tex]
If so, first put it in the form of y = f(x), that is, y is a function of x. Isolate y all by itself on the left side of the = sign.
Then I think you will see that it is not in the form of a straight line, like y = mx + b
If it's not a straight line, how do you find the slope of the curve at some point?
KrazyFire
Hey and thx :)
So the x- axis would be [tex]1/\sqrt[]{}3[/tex]X
Althought what would be the angle of the equation exactly
Its a Multiple Choice:
A) 30 Deg.
B) 120 Deg.
C) 150 Deg.
D) 60 Deg.
berkeman
Mentor
63,222
14,150
Hey and thx :)
A) 30 Deg.
B) 120 Deg.
C) 150 Deg.
D) 60 Deg.
Could you please show your work step-by-step? You need to end up with an equation y = f(x)
Have you had calculus yet? If not, it may be easiest to just graph the function y= = f(x) and estimate the angle. The choices you are given are far enough apart, so you should be able to estimate the answer pretty well.
KrazyFire
Well y=-(1/squared root 3)x+12/squared root 3
and f(x)=-[tex]1/\sqrt{}3x[/tex]+[tex]12/\sqrt{}3[/tex]
and by using the 1,2 and[tex]\sqrt{}3[/tex] triangle
I got 30 Deg. :/?
berkeman
Mentor
63,222
14,150
I got 30 Deg. :/?
That does not look right. When you start with this:
What is the first step to start isolating y all by itself on the left of the = sign? And then what do you have to do to BOTH sides to get the SQRT off of the y? When you do that to both sides, you will not end up with x or SQRT(x) on the right. What do you end up with?
KrazyFire
I am struggling with much demand of help in need :/
and as i have exam tomorrow i really need to brush off all these kinds of exact value questions...
Pls can you help me and answer it so i can see where to get the answer :)?
berkeman
Mentor
63,222
14,150
No, sorry. We do not give answers here on the PF.
This is just an algebra problem. How do you isolate the y here? Just do it step by step. The first step is to get the x term onto the righthand side (RHS) of the equation. Show us what that looks like.
Then what do you do to both sides of the equation to turn
[tex]\sqrt{3y}[/tex]
into just
[tex]3y[/tex]
KrazyFire
Okay so what I have done is:
1) Make everything to y= which is:
[tex]\sqrt{}3[/tex]y= -x+12
2) take the Squared root over to make it:
3y=x(squared)-24x+144
berkeman
Mentor
63,222
14,150
Great! You're almost there...
KrazyFire
Yeah, okay, but how do we get the angle from that equation though?
berkeman
Mentor
63,222
14,150
If you have taken calculus, you would differentiate the equation to get dy/dx, and set the x and y values to where the curve y = f(x) crosses the x-axis.
Without calculus, you need to plot the curve, to see what the angle is when it crosses the x-axis.
What is the value of y when the curve crosses the x-axis?
KrazyFire
dy/dx of the equation= 2x-24
berkeman
Mentor
63,222
14,150
You forgot to take the 3 across the = sign from the LHS to the RHS.
But you're on the right track. Once you get the correct dy/dx, you need to plug in the number for where the curve crosses the positive x-axis. To find that, I think you will need to factor the equation y = f(x) to find where the curve crosses the x-axis. It may cross it more than once, so be sure to check that you find a solution for the positive x-axis.
