The base of the pyramid is 100 blocks by 100 blocks
In summary, the total number of blocks in the base of the pyramid is 10,000. The surface area of the base of the pyramid is 10,000 square blocks. The base of the pyramid has 4 sides. The height of the pyramid is not specified in the statement and cannot be determined based on the given information. The number of blocks needed to build the entire pyramid would depend on the height and shape of the pyramid, which is not specified in the statement. Therefore, the number of blocks cannot be determined based on the given information.
florino23
i need help with this problem
The base of the pyramid is 100 blocks by 100 blocks; each successive layer is one less block wide and deep, until the top layer which is simply one block. Each block is 97 cm wide by 97 cm deep by 63 cm tall.
If one liter of paint can coat exactly three square meters, how many liters are required to coat the entire exposed surface of the pyramid? Round up to the nearest liter.
Mathematics news on Phys.org
just sum it,round it and divide it
You will get 7251 litres
thanks for the help
1. What is the total number of blocks in the base of the pyramid?
The total number of blocks in the base of the pyramid is 10,000.
2. What is the surface area of the base of the pyramid?
3. How many sides does the base of the pyramid have?
4. What is the height of the pyramid?
5. How many blocks would be needed to build the entire pyramid?
  • General Math
Writing: Input Wanted Great Lakes Earth Map
  • Thermodynamics
