Homework Help: The Carnot Engine Problem
  1. Sep 22, 2010 #1
    A Carnot heat engine operates between temperatures Th and Tc.
    (a) If Th = 515 K and Tc = 363 K, what is the efficiency of the engine?
    0.30 Your answer is correct.
    (b) What is the change in its efficiency for each degree of increase in Th above 515 K?
    ? K-1
    (c) What is the change in its efficiency for each degree of change in Tc?
    ? K-1
    (d) Does the answer to part (c) depend on Tc?
    Yes or No?
    Explain.
    2. Relevant equations
    e_c = 1 - T_c/T_h
    3. The attempt at a solution
    (a)
    T_h = 515k
    T_c = 363k
    e_c = 1 - T_c/T_h = 1 -363k/515k = 0.2951456311 = 0.30
    I'm don't know how to start part (b). Do I use the same equation or a different one?
  3. Sep 22, 2010 #2
    kuruman
    You want to find the rate of change of the efficiency e with respect to Th. Rate of change is also known as ...? (Hint: It's the "D" word.)
  4. Sep 22, 2010 #3
    So do the derivative of e = 1 - T_c/T_h ?
  5. Sep 22, 2010 #4
    kuruman
  6. Sep 22, 2010 #5
    e = 1 - T_c/T_h
    How do you do the derivative of that equation?
    dE = -ln(T_h/T_c) ?
  7. Sep 23, 2010 #6
    kuruman
    Would it help if you said let x = TC and wrote
    e = 1 - x/TH?
    Can you find de/dx ?
  8. Sep 23, 2010 #7
    Actually I did not have to do the derivative. It was so simple roflol.
    b) Increase T_h by one and calculate the efficiency
    1 - 363/516= 0.2965
    calculate difference from the original efficiency
    0.2965-0.2951=.0014
    c) Decrease T_c by one and calculate
    1 - 362/515= 0.2971
    Now find the difference
    .2951 - .2971= 0.002
    d) No
