shiva999
- 12
is that true that the colour of sky is blue or is it just the reflection of sea water
jewbinson said:But the sky's blue colour tends to be lighter than the colour of the sea (apart from seas in exotic Islands which can be very light blue).
When the sky is cloudy, the sea still tends to be quite dark blue.
shiva999 said:is that true that the colour of sky is blue or is it just the reflection of sea water
LostConjugate said:I can't take it any longer! Someone just tell jewbinson that the ocean is blue because the sky is blue.
Drakkith said:I don't think that's true though.
jewbinson said:?
This simply isn't true. When the sky is cloudy, is the sea white?
At night, there is nothing to light up the ocean, and water does not emit light, so obviously you see black (apart from the reflection of the moon)
LostConjugate said:Well yea at sunset the ocean is red.
Drakkith said:If so that is only because there is no blue light to see anyways, so of course it wouldn't appear blue. You wouldn't call a white sheet of paper red simply because it is sunset and the only light hitting it is on the red end of the spectrum would you? The fact is that water IS blue. The color that it can APPEAR to be varies depending on the impurities in the water and of course the ambient light.
See here: http://en.wikipedia.org/wiki/Color_of_water
Edit: Let us not mix up the COLOR of an object with the wavelengths that it absorbs or passes. The color can vary with the ambient light but the latter cannot.
The blue tint of water is an intrinsic property and is caused by selective absorption and scattering of white light.
LostConjugate said:Are you sure?
It says here:
Edit: Oh I guess that is the definition for the color of a molecule. Does that mean that the sky is blue as well then?
Drakkith said:In my opinion that question is a bit more complicated than one might think. The atmosphere passes the entire visible range of the spectrum. HOWEVER, it causes differing amounts of refraction along the visible spectrum. When I look through my telescope at a white star high in the sky, it appears white. However, when it is low on the horizon the star shifts around and wavers, and it changes colors between white and reddish and back and forth several times a second. This is because of the increased amount of atmosphere that is between the star and myself and because of the angle that the light is entering at.
I would say that the sky looks blue, but it only has a color if you consider a prism to have a color simply because you are looking into one of the refracted colors.
Dr_Morbius said:Sunsets are red for the same reason that the sky is blue. When you look at the sun near the horizon the atmosphere preferentially scatters the blue light away from your eye more than the red light. That makes the sun look redder than usual. The affect is increased by the fact that when the sun is near the horizon you're looking through more atmosphere than when it's overhead.
klimatos said:I disagree. If it were simply a matter of the distance traveled, then red sunsets would not be more common after volcanic eruptions, forest fires, and other sources of aerosols; and less common in clean air. Moreover, reflection and scattering is just as likely to be toward the viewer as away. Finally, in the years I've spent at sea I have seen many sunsets when the sky is blue right down to the horizon.
Your interpretation seems to be shared by a number of online sites, but all of my meteorology texts attribute red sunsets to aerosols. That's what I used to teach, and I'll stand by it.
Drakkith said:I cannot agree with any meaningful portion of the color of water being because of blue scattered light from the sky. The amount of light NOT scattered that does hit the water vastly outdoes the small amount of scattered blue light that does.
Drakkith said:And if you think about it, if the light coming down gets scattered slightly, then the added scattered light plus the non scattered light should equal out anyways.
jewbinson said:I would say reflection is a partial explanation.
