The commutator [L,p]
How do i compute the commutator [L,p]?
Answers and Replies
292
Read the forum guidelines.
You should know from your class that the commutator [x, y] = xy - yx
you can express the L operator in terms of the coordinates x,y,z and the momentum operator p. Apply the commutator to a wavefunction psi and simplify!
Hope that gave you a clue.
Meir Achuz
159
use L=rXp in the commkuator.
I find 2ihp, is that correct? do you know the correct answer?
dextercioby
Insights Author
13,207
795
First of all, both L and p are vectors, so the commutator should be computed componentwise. Next, you need to find a common dense everywhere domain for the commutator, it's not difficult to see that on the Schwartz space over R^3 both the momentum and the angular momentum operators are essentially self-adjoint and the invariance conditions are met. Therefore,
[tex] [L_{i},p_{j}]_{-}\psi (\vec{r})=... [/tex]
and , without doing any specific calculations (derivatives i mean), using the fundamental comm. relations (also valid on the Schwartz space) and some simple Levi-Civita pseudotensor manipulations, you can find the answer.
Meir Achuz
159
No its more complicated than that. Use Cartesian coordinates with
[x,px]=i and (rXp)_i=epsilon_ijk x_ip_j.
r = (x, y, z) and p = (px, py, pz).
I assume you know how to take a cross product. The only other thing is that p = -i\hbarh\del which acts on the wavefunction \Psi, and you can't exchange r and p (ie. rxp is not the same as pxr)
I hope that helps
Related Threads on The commutator [L,p]
  • Last Post
  • Last Post
  • Last Post
21K
  • Last Post
  • Last Post
14K
  • Last Post
