The Contour |C|
  • Thread starter Bachelier
I have a question pertaining to Complex Analysis.
We define a contour ##C## as a piecewise smooth arc.
For a variable ##z \in \mathbb{C}## I have seen the notation of a contour ##|C|##. It is sometimes defined as ##|C| := z([a,b])## where ##[a,b]## is a closed interval.
Should I read this as the parametrization of the contour ##C## between ##a, \ b##?
Or does ##|C|## have a different meaning ##w.r.t.## contours?
Thanks
Answers and Replies
I like Serena
6,577
176
The notation ##|C|## indicates a norm that has a curve as its argument.
The obvious norm is the length of the curve.
Your definition looks faulty.
If your curve ##C## is a continuously differentiable function ##z: [a,b] \to \mathbb C##, then:
##C=z([a,b])##
##|C|=\int_a^b |z'(t)|dt##
Note that the norm of ##C## is deduced from the norm on ##\mathbb C##.
3,297
Thanks
Do you have a reference for this?
##C=z([a,b])##
Thank you I.L.S. :)
I clearly see your point, but I think the speaker in this case gave a different definition to ##|C|## to that of the length, as he has defined the length by ##L(C) = \int_a^b \ |z'(t)| \mathrm{d}t##.
I think he meant that ##|C|## is the curve by itself without the interior as he sometimes used the notation: ##|C| \ \bigcup \ Interior(C)##.
##(Interior(C)## not to be confused with ##C^\circ)##.
But the problem is that he used ##C \ \bigcup \ Interior(C)## as well. So I think it was just a forgetful omission in the latter.
Since I searched for the symbol ##|C|## and it is not existent in any textbooks, it must thus be a nomenclature he decided to create.
I like Serena
6,577
176
Perhaps it's intended to denote the closure.
##(Interior(C)## not to be confused with ##\mathring{C})##.
What is the difference between these two?
I haven't seen ##\mathring{C}## before, although I know that ##C^\circ## is one of the notations for the interior.
you got it. Thanks
Related Threads on The Contour |C|
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
