The density of a cube.
college boy19
One end of a light thin string is attached to the bottom of a 3.7 g, 42 cm3 cork. The other end is attached to a 58 g cube. The arrangement is placed in water and it is found that with 82% of the cork submerged the cube is held in equilibrium. What is the density of the cube in g/cm3?
I need help figuring out this problem.
Answers and Replies
tiny-tim
25,836
255
Welcome to PF!
Hi college boy19! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
Show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
college boy19
okay,
the density of an object is its mass divided by its volume:
D=m/v
so for the cube all i have in the equation is :
D= 58g/v
So i know that in order to get the density i need the volume of the cube.
this is where i am stuck.
tiny-tim
25,836
255
Hi college boy19! :smile:
That's not the only way to get the density …
you can also work it out from the forces on the cork :wink:
college boy19
Well the forces acting on the cork are the buoyant force which is the the weight of the cork which is mg which is:
BF= 3.7*g
but gravity in SI units is 9.8kg/m^3 and I am using CGS units so gravity is 98g/cm^3
So the weight of the cork is
BF= 3.7(98)=362.6
the buoyant force = to the weight of the displaced fluid
tiny-tim
25,836
255
No, the forces acting on the cork are the buoyant force, the weight, and the tension in the string.
college boy19
the buoyant force:
362.6
the weight:
mg=362.6
how do i figure out the tension in the string?
is it the buoyant force - the weight of the cube
tiny-tim
25,836
255
the buoyant force:
362.6
the weight:
mg=362.6
How can the buoyant force be equal to the weight?
How is buoyant force defined?
You have two equations for it …
one for the cork, and one for the mass …
that should be enough to solve the whole problem. :smile:
Suggested for: The density of a cube.
  • Last Post
  • Last Post
15K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
