What is the explanation behind the diagonal (pseudo)paradox in mathematics?
  • Thread starter radou
In summary, the conversation discusses the diagonal paradox, which involves the approximation of the diagonal with a finite number of line steps. It is noted that in the limit as the number of steps tends to infinity, the step converges to the diagonal. However, the paradox arises because the measurements of length of the two lines do not agree, and it is not possible to interchange limits and lengths. The conversation also touches on the concept of convergence and its application to this paradox.
radou
Homework Helper
3,149
http://mathworld.wolfram.com/DiagonalParadox.html
the approximation of the diagonal with a finite nuber of line steps only appears (to the eye) as the real diagonal for a very large n, but as long as we consider it an approximation, it's length (the summation of horizontal and vertical steps) is always be 2. it's only a problem of your point of view, so i don't really see a paradox here..does someone have a better idea?
Mathematics news on Phys.org
In the limit as the number of steps tends to infinity the "step" converges to the diagonal. Of course "converge" requires a distance notion, but in any reasonable notion of the distance between to functions they do indeed converge. The "paradox" is just that the measurements of length of the two lines do not agree, ie you cannot interchange limits and lengths. as with all paradox it only contradicts what "most" people expect, ie it is surprising that we can't interchange them.
yup, that was my point :) so, i guess the wolfram crew should mention these few facts :)
Another way of stating what is going on generally.
Suppose that X(n) is a sequence of objects that have a meaningful limit X. If all of hte X(n) have a property P, then when does X have property P. There are numerous theorems in maths that follow this pattern.
the paradox here is that most people will accept that the limit must have P without thinking about. there are indeed many people who use such fallacious reasoning to claim things in maths that are patently absurd.
Hello Matt. I do not relish the though of taking issue with you but feel the step never converges to the diagonal. This is my arguement: The total length of step is:
[tex]n(2)(\frac{1}{n})[/tex]
So even as n goes to infinity, the length of steps remains at 2.
However, the sum of all the diagonals of these steps is:
[tex]a(\frac{\sqrt{2}}{a})[/tex]
And that expression is always [itex]\sqrt{2}[/itex] even as a tends to infinity.
Would you kindly provide a proof showing that the step function as defined in the Wolfram document converges to the diagonal.
saltydog said:
Hello Matt. I do not relish the though of taking issue with you but feel the step never converges to the diagonal. This is my arguement: ...
Didn't Matt just make two postings pointing out that it's wrong to assume that a sequence of curves of length 2 must necessarily converge to a curve of length 2?
When i said "of course converge requires a distance notion, but in any reasonable notion of the distance between to functions they do indeed converge" i meant it. in what sense do you think they don't converge, saltydog? pointwise? the sup norm? the "l^1" norm (ie the integral of the area between them)? (the step functioon isn't admittedly a a cont function from R to R at first glance, but twist the picture 45 degrees so it's a sawtooth if you need to)
some properties do pass through limits some do not, it is important to fidn out which ones can be presumed to do so.
Hello Matt. Glad you didn't exhibit offense at my insolence. I am in error sir and yield to you.
My disagreement stemed from my view that the arc lengths of both the diagonal and the step function never seem to match. However your statement that the area between the two necessarilly goes to zero is intutitive justification for me that they converge. However, this seems to be point-wise convergence.
However, I still have a problem resolving the conflict with the two arclengths: It seems to me that even though the step function converges to the diagonal, the arc-length always remains at 2 whereas the diagonal is root(2). Is this due to the nature of point-wise convergence or to my lack of familiarity with the subject?
What is the diagonal (pseudo)paradox?
The diagonal (pseudo)paradox is a thought experiment that explores the concept of infinity and sets. It was first introduced by mathematician Georg Cantor in the late 19th century.
How does the diagonal (pseudo)paradox work?
The diagonal (pseudo)paradox works by showing that there is no one-to-one correspondence between the real numbers and the natural numbers, despite both sets being infinite. This challenges the common understanding that all infinite sets are the same size.
What is the significance of the diagonal (pseudo)paradox?
The diagonal (pseudo)paradox has had a profound impact on mathematics and philosophy. It has led to the development of new theories and concepts, such as Cantor's theory of transfinite numbers and the concept of different levels of infinity.
Can the diagonal (pseudo)paradox be resolved?
There is no consensus on whether the diagonal (pseudo)paradox can be resolved. Some mathematicians argue that it is a true paradox, while others believe that it can be explained through new concepts and theories.
How is the diagonal (pseudo)paradox relevant to real-life situations?
The diagonal (pseudo)paradox has implications in fields such as computer science, where it is used to understand the limitations of computing and the concept of computability. It also has philosophical implications, challenging our understanding of infinity and the nature of reality.
  • Set Theory, Logic, Probability, Statistics
  • Quantum Physics
