The downfall of education in Australia
In summary, a university lecturer suggested that playing a stream of sound backwards would cancel out the sound, but this is not true. While destructive interference can occur at certain points, the energy of the sound cannot be cancelled. Additionally, simply playing the stream backwards does not invert the signal and precise positioning and damping are needed to cancel out sound at specific points. High frequencies are difficult to cancel and even a slight movement can affect the audibility of the sound.
Adam
65
I'm not really debunking anything, but I didn't know where else to put this. One of the chaps I hang out with sometimes used to lecture computer science at a Melbourne university. He's done some physics of course - you must in such degrees. So we're all talking crap one day, and this fellow pipes up with the idea that playing a stream of sound backwards in opposition to the stream itself (ie. if you play Stairway backwards from point A while it is played normally from Point B), you cancel out the sound, so there is silence. I can only assume the person has absolutely no idea what destructive intereference is all about. A truly whacky idea, and this was from a university lecturer. Amazing but true!
Since you took the time to tell the story I want to explain your objection a little more.
Firstly, it is possible to destructively interfere two sound waves at a point or along a mathematical surface, but the energy can not be cancelled. If the sound interferes destructively at one point, it must [by the demand for conservation of energy] likewise interfere constructively to the same degree at another point or over some volume [edit: or we at least need to sum the energy over all space in which case it all still adds]. Another way to say this is that both the inverted and primary waves each come with only positive energy.
Next, simply playing the stream backwards does not invert the signal. A one-to-one mapping of the incoming wave is needed; with a rarefied volume of air meeting a compressed volume of exactly equal and opposite magnitude. At some random point, if we take a freeze frame of the sound wave in the stream and look at the wave we see some value that we might call positive - let's say this is a push out for the speaker. Displacement at a point in the stream is still positive regardless of the direction from which it is approached. To create an inverted wave would require that all positive displacements are made negative – the speaker is pulled in instead of pushed out. This must track exactly throughout the entire stream. Then, it is only possible to hear this at a specific point or along some line.
If you have a large room handy, one way to get this effect [a little] is to simply reverse the polarity of the speakers. Then, by placing the speakers next to each other, if you stand in front of them at a distance of about six feet, a significant reduction in the bass can ususally be detected by ear. If you walk around the room you should be able to detect hot and cold spots. Moving the speakers around can create different regions in space in which the low frequencies tend to cancel. The same effect can be found without even reversing the wires. Note also that high frequencies are very difficult to cancel at a specific point. This requires very precise positioning of all elements in addition to damping of ambient sound. I imagine the dynamic response of the speaker begins to kill the effect at high frequencies. The phase opposition is not likely preserved.
I once played with some high frequency speakers and had some really interesting interference results from the 20KHz range. Being just at the upper frequency limit and the minimum amplitude limit for hearing, and with a wavelength of about 1/2 inch, as the 20KHz wave interferes with itself around the room, just a slight movement of one's head makes the sound audible or not. I could hear it as I sat, but if I turned my head only slightly the sound was completely inaudible.
First of all, I want to clarify that one individual's misunderstanding or incorrect idea does not represent the entire education system in Australia. While it is concerning that a university lecturer would have such a misconception, it is unfair to generalize and say that education in Australia is in a downfall.
Furthermore, it is important to recognize that education is a constantly evolving field and mistakes or misunderstandings can happen. However, it is the responsibility of educators to continuously educate themselves and stay updated on current information and research. It is also the responsibility of students to critically think and question information presented to them.
In this specific case, it seems that the lecturer in question may have lacked a thorough understanding of physics and how sound works. This does not reflect on the overall quality of education in Australia. In fact, Australia has a strong education system with highly ranked universities and a high literacy rate.
It is important to not let one anecdote overshadow the hard work and dedication of educators and students in Australia. There may be room for improvement in certain areas, but it is unfair to paint the entire education system in a negative light based on one individual's mistake. Let us instead focus on supporting and improving education in a constructive manner.
1. What factors have contributed to the decline of education in Australia?
There are several factors that have contributed to the decline of education in Australia. One major factor is the lack of funding and resources for schools, which has led to overcrowded classrooms and limited access to technology and other learning materials. Another factor is the increasing focus on standardized testing, which often leads to a narrow curriculum and neglect of other important skills and subjects. Additionally, there has been a decline in the quality of teaching due to low pay and high workload, leading to a shortage of qualified and experienced educators.
2. How has the decline of education in Australia affected students?
The decline of education in Australia has had a significant impact on students. With overcrowded classrooms and limited resources, students may not receive the individual attention and support they need to succeed. The emphasis on standardized testing can also create a high-pressure and stressful learning environment for students. Furthermore, the decline in the quality of teaching can result in students receiving a subpar education, which can hinder their future academic and career opportunities.
3. Are there any efforts being made to improve education in Australia?
Yes, there are ongoing efforts to improve education in Australia. The government has implemented various initiatives, such as the National Education Reform Agreement, which aims to improve funding and support for schools. There are also programs in place to attract and retain high-quality teachers, as well as initiatives to address issues of inequality and disadvantage in education. However, more needs to be done to address the root causes of the decline in education in Australia.
4. How does the decline of education in Australia compare to other countries?
The decline of education in Australia is a global issue, and many other countries are facing similar challenges. However, according to international assessments, such as the Programme for International Student Assessment (PISA), Australia's education system has been declining in recent years. This is a concern, as education is a critical factor in a country's economic and social development.
5. What can be done to reverse the decline of education in Australia?
To reverse the decline of education in Australia, there needs to be a comprehensive approach that addresses the various factors contributing to the issue. This includes increasing funding and resources for schools, reducing the emphasis on standardized testing, and improving the quality and support for teachers. Additionally, there needs to be a focus on promoting equity and addressing inequality in education, as well as involving stakeholders, such as parents and communities, in the education system. Ultimately, it will require a collective effort and commitment from all levels of government and society to reverse the decline of education in Australia.
  • STEM Academic Advising
  • General Discussion
  • STEM Educators and Teaching
41K
