Homework Help: The Formula
  1. Jul 11, 2006 #1
    V= at or velocity = acceleration x time square
    so how did they arrived like this formula?
    thank you for your reply
    need help ,
    gen
  3. Jul 11, 2006 #2
    The correct relation is v = u + at or a = (v-u)/t
    where u stands for initial velocity, v final velocity, and a the [B}constant linear[/B] acceleration.
    The result follows since acceleration is defined to be the time rate of change of velocity, and since this rate is a constant here, you can simply take the ratio of the difference between any two velocities at different times, to the time taken . Hence the second equation.
    Or simply,
    [tex]a=\frac{dv}{dt}[/tex]
    [tex]\int adt=\int dv[/tex]
    [tex]v=at+C[/tex]
    where C is the constant of integration.
    Putting t=0 in the expression, we get v=c=u.
    The result follows.
  4. Jul 14, 2006 #3
    hooray for calculus
  5. Jul 14, 2006 #4
    HallsofIvy
    For the simple "constant acceleration" case, acceleration is defined as "change in speed"/"change in time". From that you immediately get "change in speed"= acceleration*"change in time" by multiplying both sides of the equation by "change in time".
    Notice that the equation you give: v= at is incorrect in general. Writing [itex]\Delta v[/itex] for "change in speed", if t represents the length of time accelerating, then [itex]\Delta v[/itex]= at. [itex]\Delta v= v[/itex] only if the initial velocity is 0. If the initial speed is v0 we can get the final speed by adding "change in speed" to "initial speed":
    v= at+ v0.
    If the acceleration is not constant, then "change in speed" divided by "change in time" only gives average acceleration. The acceleration at each time is "derivative of speed function with respect to time":
    [tex]a(t)= \frac{dv(t)}{dt}[/itex]
    and we go from acceleration to speed by integrating:
    [tex]v(t)= \int_{t_0}^t a(t)dt[/itex]
