What is the Fundamental Period of sin(5t + π) on the Interval (-∞, +∞)?
In summary, In order to find the LCM of pi/2 and 3pi/4, you would need to use the Least Common Multiple.
darkmagic
164
The function is defined on (-infinity, +infinity)
Find the fundamental period of sin(5t+[tex]\pi[/tex])
f(x)=sin(5t+[tex]\pi[/tex])
f(x)=f(x+2p)
f(x+2p)=sin(5t+[tex]\pi[/tex]+2p)
f(x+2[tex]\pi[/tex]/5)=sin(5t+[tex]\pi[/tex]+2[tex]\pi[/tex]/5)
The period i got was 2[tex]\pi[/tex]/5
f(x+2[tex]\pi[/tex]/5)=sin(5t+7[tex]\pi[/tex]/5)
f(x+2[tex]\pi[/tex]/5)=sin5tcos7[tex]\pi[/tex]/5 + cos5tsin7[tex]\pi[/tex]/5
What should I do next?
I don't know how can I go back to the original function.
The period of y = sin(t) is 2pi, right?
The graph of y = sin(At) is a compression of y = sin(t) by a factor of A toward the y-axis if A > 1, and is the expansion away from the y-axis by a factor of 1/A if A < 1.
So for example, y = sin(3t) is compressed toward the y-axis by a factor of 3, with the result that its period is 2pi/3. Your function can be written as f(x) = sin(5(t + pi/5)). All that the pi/5 represents is a translation to the left of the graph of y = sin(5t) by pi/5 units, so doesn't affect the period at all.
Nuff said?
where does pi/5 came from? what do I do to the 2pi/5 period?
Sin(x) has period [itex]2\pi[/itex]. That means one period starts when x= 0 and ends when [itex]x= 2\pi[/itex]. For [itex]sin(5t+\pi)[/itex], then, one period starts when [itex]5t+ \pi= 0[/itex] and ends when [itex]5t+\pi= 2\pi[/itex]. From [itex]5t+\pi= 0[/itex], [itex]5t= -\pi[/itex] so [itex]t= -\pi/5[/itex] and from [itex]5t+\pi= 2\pi[/itex], [itex]5t= \pi[/itex] so [itex]t= \pi/5[/itex]. That means that one period of [itex]sin(5t+ \pi)[/itex] starts at [itex]-\pi/5[/itex] and ends at [itex]\pi/5[/itex], for a total length of [itex]\pi/5-(-\pi/5)= 2\pi/5[/itex]. Yes, the period is [itex]2\pi/5[/itex], just as you say.
Now, your main question appears to be showing that, in fact, [itex]f(t+ 2\pi/5)= f(t)[/itex]. Your error is that you just added [itex]2\pi/5[/itex] to the argument of sin rather than to x.
That is, you do NOT want "[itex]sin(5t+\pi+ 2\pi/5)[/itex]" .
You want, rather, [itex]sin(5(x+ 2\pi/5)+ \pi)[/itex][itex]= sin((5x+ 2\pi)+ \pi)[/itex][itex]= sin((5x+ \pi)+ 2\pi)[/itex]. Using the sum formulas as you do now gives [itex]sin(5(x+2\pi/5)+\pi)[/itex][itex]= sin((5x+\pi)cos(2\pi)+ cos(5x+\pi)sin(2\pi)[/itex]. And, because, of course, [itex]cos(2\pi)= 1[/itex] and [itex]sin(2\pi)= 0[/itex], that is just [itex]sin(5x+ \pi)[/itex] again.
so 2p will only be added to t since the part 5t determines the period? ok i understand what you said thanks...
oh i see... so you regroup the 5t+2pi+pi into (5t+pi)+2pi?
how about if you don't regroup it?
how about if the function comes in many terms?
for example: 1+cost+cos2t
Will I get the larger period among them or use the LCM?
if LCM, how do I do that?
what should I do?
In order that the function repeat, all parts must repeat which means you need the Least Common Multiple. But in this case, since the periods are [itex]\pi[/itex] and [itex]2\pi[/itex], that is the same as the largest period!
If the periods were, say, [itex]\pi/2[/itex] and [itex]3\pi/4[/itex], then the period of the sum would be [itex]3\pi/2[/itex].
how do I can solve for the LCM if the given is fraction?
See HallsOfIvy's last post where several periods are given that are fractional parts of pi. If that's not what you're asking, you need to be more specific.
Im talking about his last post, pi/2 and 3pi/2, how it became 3pi/2. All I know about LCM is it for whole number just like the LCM of 3,5,and 15 is 30. For fraction, it is LCD.
The LCM of pi/2 and 3pi/2 is 3pi/2, for the same reason that the LCM of 3 and 9 is 9. For the LCM of a group of numbers, you want the smallest number that all the numbers evenly divide.
a mistake. it should be pi/2 and 3pi/4 is 3pi/2 there LCM.
What's the smallest number that pi/2 and 3pi/4 both divide evenly?
On a different matter, the use of punctuation would help you communicate more effectively.
This is two sentences masquerading as one, so is harder to understand than is necessary.
Am i correct?
the multiples of pi/2 are pi/2, pi, 3pi/2, 2pi...
the multiples of 3pi/4 are 3pi/4, 3pi/2,9pi/4...
so the LCM is 3pi/2.
without using the listing of multiples, will this work?
lets say, find the LCM of pi/2 and 3pi/4
Using LCD pi/2 becomes 2pi/4 and 3pi/4 is still 3pi/4
By multiplying 2 and 3, it becomes 6
Then the LCM is 6pi/4 or 3pi/2
is my last post correct?
Yes, but you could have verified this by listing the multiples of pi/2 and 3pi/4.
1. What is the Fundamental Period?
The Fundamental Period, also known as the natural period or basic period, is the characteristic time it takes for a system to complete one full cycle of oscillation or vibration.
2. How is the Fundamental Period calculated?
The Fundamental Period is calculated by taking the reciprocal of the frequency of the system. This can be found by dividing the number of cycles completed in a given time by that time.
3. What factors affect the Fundamental Period?
The Fundamental Period is affected by the physical properties of the system, such as mass, stiffness, and damping. It is also influenced by external factors, such as the magnitude and frequency of applied forces.
4. What is the importance of knowing the Fundamental Period?
Knowing the Fundamental Period is important in understanding the behavior and stability of a system. It is also crucial in designing structures, such as buildings and bridges, to withstand external forces and prevent resonance.
5. Can the Fundamental Period change over time?
Yes, the Fundamental Period can change over time due to factors such as aging of materials, changes in loading conditions, or structural modifications. It is important to regularly reassess the Fundamental Period to ensure the safety and stability of a system.
