I The general Lorentz transformation
Hi guys, I'm reading a book 'the theoretical minimum: special relativity and classical field theory'. In chapter 1.3, author explains the general Lorentz transformation.
He said "Suppose you have two frames in relative motion along some oblique direction, not along any of the coordinate axes. It would be easy to make the primed axes line up with the unprimed axes by performing a sequence of rotations. After doing those rotations, you would again have uniform motion in the x direction. The general Lorentz transformation—where two frames are related to each other by an arbitrary angle in space, and are moving relative to each other in some arbitrary direction—is equivalent to:
1. A rotation of space to align the primed axes with the unprimed axes.
2. A simple Lorentz transformation along the new x axis.
3. A second rotation of space to restore the original orientation of the
unprimed axes relative to the primed axes. "
My head is stuck with that paragraph and I can't understand how he can do that. I can't visualize it in my head. Could anyone make me grasp it?
Ibix
Insights Author
4,995
3,309
If the velocity you want to boost in isn't the x direction, then you rotate your axes (you can imagine a little construction of rods pointing in three directions that you imagine rotating) so that the new x direction does point in the direction you want to boost. Then you boost. Then you rotate your axes back to how they were before.
Want to reply to this thread?
"The general Lorentz transformation" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
