The gradient of a tensor
  • Thread starter EsmeeDijk
We have the following orthogonal tensor in R3:
[itex] t_{ij} (x^2) = a (x^2) x_i x_j + b(x^2) \delta _{ij} x^2 + c(x^2) \epsilon_ {ijk} x_k [/itex]
Calculate the following quantities and simplify your expression as much as possible:
[itex] \nabla _j t_{ij}(x)[/itex]
and
[itex] \epsilon _{ijk} \nabla _i t_{jk}(x) = 0 [/itex]​
The equations given in my book are:
[itex] (\nabla f)_i = \Lambda _{ji} \frac{\partial f}{\partial x_j} [/itex] ( with a tilda on the last xj
[itex] \nabla _i = \Lambda_i^j \nabla _j [/itex] (with a tilda "~" on the last nabla)
My problem is that these equations that I have are all assuming that you have a tensor in the form of a matrix, but this is not the case I believe. Also in the book leading up to these equations you have a vector x which is dependent on xi and on ei. Which is now also not the case. Only the first term with a is dependent on xi or xj, but I can't imagine that the rest of the function just falls away..
Answers and Replies
andrewkirk
Insights Author
1,435
Your notation is unfamiliar.
What do ##x,x^2## and ##x_i## represent in your formula?
Does ##t_{ij}(x^2)## represent the ##i,j## component of the tensor, in some assumed (but unstated) basis, calculated in terms of a parameter ##x^2##? Or does it represent the application of an order-2 tensor to a vector denoted by the symbol ##x^2##?
Related Threads on The gradient of a tensor
  • Last Post
45K
  • Last Post
63K
  • Last Post
15K
  • Last Post
