Understanding the Total Energy of a Hamiltonian
In summary, the Hamiltonian, H, is conserved if it has no explicit time dependence. If the generalized coordinates do not depend explicitly on time, and if the potential is independent of the velocities, then H is the total energy. However, if H is not in this form, like in the case of a charged particle moving in a magnetic field or in the case of time varying constraints, then H is not the total energy.
jsc314159
I have a question on the Hamiltonian from a classical viewpoint.
I understand that the Hamiltonian, H, is conserved if it has no explicit time dependence, in other words:
[tex]
\frac{\partial H}{\partial t} = 0
[/tex]
What I am not clear on is how one can determine whether a given Hamiltonian represents the total energy of the system by looking at its form.
Can someone explain this?
Thanks,
JSC
So, if H is in a form H = T + V, H represents the total energy.
However, if H is not in this form, like in the case of a charged particle moving in a magnetic field or in the case of time varying constraints, then H is not the total energy. Is this right?
I suppose I am somewhat confused over this because the form of the Hamiltonian can change significantly when the generalized coordinates are changed (see the spring mass on the cart moving with uniform velocity, Goldstein, Classical Mechanics 3rd Ed, pp. 345-347).
No, the requirement is that (1) the generalized coordinates do not depend on time and (2) The potential does not depend on p.
In the case of a particle moving in an EM field, the hamiltonian [tex]H=\frac{1}{2m}\left(\vec p -\frac{q}{c}\vec A\right)^2 + q\phi[/tex] is not in the form H=T+V, but it is still the total energy because the coordinates are simply the cartesian coordinates and [itex]V=q\phi[/itex] does not depend on p.
So in the case of the spring-mass on a cart moving with uniform velocity, which has time varying constraints, H can be represented as:
[tex]
H = \frac{p^2}{2m} + \frac{k}{2} (x - v_0t)^2
[/tex]
if the generalized coordinate is the position x of the mass. In this case H is the total energy since x is independent of time and V is independent of velocity but H is not conserved since it is an explicit function of t.
On the other hand, if we let
[tex]
x' = x - v_0t
[/tex]
then H is written as:
[tex]
H = \frac{(p' - mv_0)^2}{2m} + \frac{kx'^2}{2} - \frac{mv_0^2}{2}
[/tex]
if the generalized coorindate is now x', the position of the mass relative to the cart. In this case H is conserved but H is not the total energy since the generalized coordinate x' is a function of time.
Correct?
I think you fall into a question of the independence of the variables.
Generally,
H = H(q,p,t)
and the three variables q,p(equal to v),t are independent, this mean that if we change one of them,the others will not change consequently.
but in your question, x,xsingle-quote ,t are not independent.Right?
Correct, x' is a function of x and t in a coordinate system moving with the cart. However, in this coordinate system H is no longer an explicit function of t.
yeah, of cause.
in fact, we can obtain the conclusion directly from the observation of the physical existence of this system instead of the mathematical expression,as long as it is in a inertia frame.
What is the Hamiltonian in physics?
The Hamiltonian is a mathematical operator in physics that represents the total energy of a system. It is used to describe the dynamics of a physical system and is a fundamental concept in quantum mechanics.
What is the significance of the total energy of a Hamiltonian?
The total energy of a Hamiltonian is significant because it is a conserved quantity, meaning it remains constant over time. This allows us to predict the behavior of a physical system and understand how it will evolve over time.
How is the total energy of a Hamiltonian calculated?
The total energy of a Hamiltonian is calculated by adding the potential energy and kinetic energy terms together. In quantum mechanics, the Hamiltonian is represented by the Schrödinger equation, which can be used to solve for the total energy of a system.
What factors affect the total energy of a Hamiltonian?
The total energy of a Hamiltonian is affected by various factors, including the mass and velocity of the particles in the system, the strength of any external forces, and the potential energy of the system. Changes in these factors can alter the total energy of the system.
Why is understanding the total energy of a Hamiltonian important?
Understanding the total energy of a Hamiltonian is important because it allows us to predict the behavior of physical systems and make accurate calculations in quantum mechanics. It also provides insight into the fundamental principles of energy conservation and the dynamics of physical systems.
  • Classical Physics
  • Atomic and Condensed Matter
  • Classical Physics
  • Quantum Physics
