The hyperbola
when an object is thrown horizontally ,after some time when the effect of the applied force is less than the effect of gravity then it changes its path and bends towards the earth and the path is called a parabola ,then in the same sense how can we define hyperbola?
Answers and Replies
Khashishi
493
Parabola and hyperbola are defined by their mathematical shape, not by physical trajectories. They are both conic sections.
WWGD
2019 Award
5,410
3,486
Why do you think there is a similar description for a hyperbola? I am not aware of any , though this of course does not mean there isn't one. But you can consider the physical aspects of parabolic mirrors/antennas and their reflecting properties.
SteamKing
Staff Emeritus
12,796
1,668
I don't know if there is a terrestrial situation which results in a hyperbolic trajectory, but it is common to find hyperbolic orbits for bodies which are traveling faster than the escape velocity of the orbited body.
It's called an escape, or hyperbolic, trajectory:
https://en.wikipedia.org/wiki/Hyperbolic_trajectory
Likes SammyS
5,910
You're misunderstanding things here. Gravity doesn't act "after some time." If the object is thrown, the only force (and hence, the only acceleration) on the object is that due to gravity. If one object is dropped straight down, and another object is thrown horizontally, both object will cover the same vertical distance in the same amount of time.
pbuk
634
If you could fire a bullet from a gun at about 25,100 mph (i.e. more than Earth's escape velocity which is 10x faster than bullets actually travel) and ignore air resistance, the bullet will follow (part of) an hyperbola.
42
The trajectory may depend on the object's initial condition and the net force it has during the whole process. The star's gravitation can make a hyperbola trajectory but it's not the way to define it.
Related Threads on The hyperbola
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
17K
  • Last Post
