The Length of the Universe
  1. Oct 6, 2005 #1
    I was researching about the highest possible EM wavelength and came across "the length of the universe" concept.
    Is it just the length of the visible universe? or the universe possible?
    thanx
  3. Oct 6, 2005 #2
    I think it maybe stating the known universe a.k.a the observable universe. :/
  4. Oct 6, 2005 #3
    Photon Phantom...
    Longest photon wavelength?
    Hubble photon wavelength:
    [tex]r_u = \lambda_{\gamma}[/tex]
    [tex]\lambda_{\gamma} = \frac{c}{H_o}[/tex]
    [tex]H_o[/tex] - Hubble Constant
    What is the 'wavelength' of this photon?
  5. Oct 6, 2005 #4
    SpaceTiger
    Staff Emeritus
    Check out this thread.
  6. Oct 6, 2005 #5
    turbo
    The highest possible wavelength is a standing wave (WRT to your frame of reference). It would be indistinguishable from the your local backgound, and therefor not measurable by you, regardless of how much energy the wave might contain.
    Interestingly, quantum physics says that the energy of the vacuum is 120 OOM larger than we can measure. Sometimes, a UV cutoff is proposed to cut this discrepancy back by about 60 OOM (yeah!:yuck:). I find it curious that these same folks do not propose an IR (actually much lower frequency!) cutoff where huge energies might be expressed at wavelengths too long for us to detect.
  7. Oct 7, 2005 #6
    Chronos
    Turbo, as you know, there is a theoretical IR cutoff, but not very firm. We run up against these kind of walls all the time - largely, IMO, because we have no viable quantum theory of gravity. Personally, I think both theories are incomplete. I hasten to add, however, I believe both theories are correct within their own domain [my inner crackpot is showing].
  8. Oct 7, 2005 #7
    so the lowest EM wavelength would be an open 1d string vibrating as a photon at planck level ???
  9. Oct 7, 2005 #8
    Chronos
    No. Empirical tests deny the 1d result at around 4 sigma levels.
  10. Oct 7, 2005 #9
    I thought it would be lower than that !!!
  11. Oct 7, 2005 #10
    A photon is a 4 dimentional entity, (3 space + 1 time) therefore no photon can exist below D = 4.
    'observable' Hubble Photon wavelength:
    [tex]\lambda_{\gamma} = \frac{3 c}{H_o}[/tex]
    Reference:
    http://universe-review.ca/F02-cosmicbg.htm
    http://universe-review.ca/R02-16-universe.htm
  12. Oct 7, 2005 #11
    Chronos
    Huh? That makes no sense at all... unless you are trying to prove 2 = 3.
  13. Oct 7, 2005 #12
  14. Oct 8, 2005 #13
    SpaceTiger
    Staff Emeritus
    I'm a bit confused about the relevance here. Why are you talking about this in terms of the longest photon wavelength?
  15. Oct 8, 2005 #14
    Chronos
    Agreed, ST. I fail to see the relevance, which is the basis of my objection.
  16. Oct 30, 2005 #15
    Nereid
    Staff Emeritus
    One could approach the OP's question as some kind of 'what if?' thought exploration; most posts in the thread are of this kind.
    Or one could approach this in terms of physical possibilities, within what we know of physics, the universe, etc.
    Or one could simply go outside and count the horse's teeth :smile:
    On the second approach. Leave aside how the longest wavelength EM (radio?) might be created, could they 'exist', in any meaningful sense? For starters, the propogation of long wavelength (low frequency) radio is limited by the plasma frequency, which is proportional to the square root of the electron density. So, the universe seems to set a low frequency bound on radio waves which can propogate, to the lowest density plasma. And where are these plasmas? What are their densities?
    Is there an 'out'? Are the large regions of space which are NOT plasmas (or, more precisely, do not contain free electrons)?
