• Support PF! Buy your school textbooks, materials and every day products Here!
The lorentz transformations usage
  • Thread starter PhMichael
There's something about the lorentz transformations which is somewhat confusing to me, and that is how to treat the "x" coordinate. Supposing I have some spaceship which is moving from earth to some other planet located at a distance "D" (from earth) with a velocity v. Now, the spacetime coordinates of the events "1. leaving earth" and "2. reaching the planet" are (the spaceship frame is {S'} and that of earth is {S} ) :
Leaving earth:
[tex] (x_{1},t_{1})=(x'_{1},t'_{1})=(0,0) [/tex]
Reaching the planet:
[tex] (x_{2},t_{2})=(D, \frac{D}{v} ) [/tex]
[tex] (x'_{2},t'_{2})=(0 , \gamma (t_{2} - (v/c^{2})x_{2})=(0 , \gamma (t_{2} - (v/c^{2})D) [/tex]
Now comes the confusing point which is how to treat [tex] x_{3} [/tex] which corresponds to the event of returning back to earth in the earth's frame. (in the spaceship frame it is [tex] x'_{3} = 0 [/tex] )
The Lorentz transformations relates coordinates and not distances so [tex] x_{3} = 0 [/tex] because the spaceship returns to the origin of earth and [tex] t_{3} = \frac{2D}{v} [/tex]. However, as I have seen in my notes:
[tex] x_{3} = 2D [/tex]
, that is, the distance that this spaceship travels is what is accounted for and not its coordinate.
Can anyone clear this point for me?
Answers and Replies
CompuChip
4,284
47
I think that must be a mistake in your notes. Assuming the turn-around is instantaneous, then in "earth coordinates" you will have x = 0, t = 2D/v for the spaceship returning on earth.
[Be aware, by the way, that you are basically working out the twin paradox.]
134
But if [tex] (x_{3} , t_{3} ) = ( 0 , 2D/v ) [/tex] then for [tex] t'_{3} [/tex] we'll have:
[tex] t'_{3} = \gamma (t_{3} - (v/c^{2}) x_{3} ) = \frac{2D/v}{\sqrt{1-(v/c)^{2}}} [/tex]
while the answer should be:
[tex] t'_{3} = \frac{(2D/v) - (2Dv/c^{2})}{\sqrt{1-(v/c)^{2}}} [/tex]
that is, [tex] x_{3} = 2D [/tex] and not [tex] x_{3} = 0 [/tex]
Why?
vela
Staff Emeritus
Education Advisor
14,469
1,129
Did you account for different Lorentz transformations because the ship is now traveling in the opposite direction?
134
vela
Staff Emeritus
Education Advisor
14,469
1,129
Because there aren't only two frames S and S'. When the ship turns around, there's now a third frame, S''. There's a different set of Lorentz transformations that relate the coordinates in S to the coordinates in S''.
134
I haven't got that ... why have you introduced a third frame? and what is it?
134
wikipedia uses some terminology that I haven't heard of :D
anyway, I noticed that if I use that same table with the invariant then I get the right answer:
Invarinat: [tex] l^{2}= (\Delta x)^{2} - c^2 (\Delta t)^{2} [/tex]
[tex] 1 \to 2 [/tex]
[tex] 24^{2} c^{2} - c^{2} 25^2 = 0^{2} - c^{2} (\Delta t')^{2} , t'_{1}=0[/tex]
[tex] t'_{2}=7 [yr] [/tex]
[tex] 2 \to 3 [/tex]
[tex] (0-24)^{2}c^{2}-(50-25)^{2}c^{2}=0^{2}-c^{2}(\Delta t')^{2} , t'_{2}=7 [/tex]
[tex] t'_{3}=14 [yr] [/tex]
which is strange because this invariant is obtaind from the Lorentz tansformation (isn't it?).
Related Threads for: The lorentz transformations usage
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
