The meaning of the relative strength of forces
In summary, the conversation discusses the concept of relative strengths of forces, specifically between gravity and electric forces. It is explained that comparing the constants of proportionality for these forces can give an idea of their relative strengths. However, due to the different units used for measuring these forces, a direct comparison is not possible and a conversion factor must be used. It is also mentioned that the relative coupling constants for the four fundamental forces play a role in understanding this concept.
Tac-Tics
816
It's common to hear people say that gravity is a "weak force" and that it is "32 times weaker than the weak nuclear force." But what does that even mean, if it has any meaning at all. The gravity on a particle is proportional to its mass. The electric force on an object is proportional to its charge. To make a statement about relative strengths, that would mean you're making an implicit statement about the relationship between an object's charge and mass, right?
Here's a simple illustration using simplifed forms of the gravitational and electric forces:
[tex]F_{g}=G\frac{m_{1}m_{2}}{r^{2}}[/tex]
[tex]F_{e}=k\frac{q_{1}q_{2}}{r^{2}}[/tex]
If we compare the constants of proportionality, k and G, we find that k=10^20 G. It's basically saying that per whatever unit the force uses to measure its strength, one force is much stronger than another.
Yeah, but that's comparing apples (mass) to oranges (charge). The units are different, so you can't simply divide and find the ratio of the strengths... you're left with a conversion factor of kg/C or something.
You are of course right. That example was pretty terrible and I was making light of what is a much more complicated situation. I don't fully understand this myself but after looking around I think it has something to do with the relative coupling constants for the four fundamental forces.
See:http://en.wikipedia.org/wiki/Coupling_constant
1. What is the relative strength of forces?
The relative strength of forces refers to the amount of force that is exerted between two objects. It is a measure of the magnitude of the force compared to other forces in a given system.
2. How is the relative strength of forces measured?
The relative strength of forces is measured using a unit called Newton (N). This unit is used to quantify the amount of force exerted between two objects. The higher the Newton value, the stronger the force.
3. What are the four fundamental forces and how do they compare in terms of strength?
The four fundamental forces are gravity, electromagnetism, strong nuclear force, and weak nuclear force. In terms of strength, strong nuclear force is the strongest, followed by electromagnetism, weak nuclear force, and gravity being the weakest.
4. Why is it important to understand the relative strength of forces?
Understanding the relative strength of forces is crucial in many scientific fields, such as physics and engineering. It allows us to predict and explain the behavior of objects and systems, and to design and create structures and machines that can withstand different forces.
5. Can the relative strength of forces change?
Yes, the relative strength of forces can change depending on the distance between objects, the mass of the objects, and the type of force being exerted. For example, the strength of gravity between two objects will decrease as the distance between them increases.
  • Other Physics Topics
  • Classical Physics
