The Minkowski equation
  1. Jul 22, 2010 #1
    The standard Minkowski 4-space equation runs like this (as far as I know);
    x'2 + y'2 + z'2 - c2t'2= x2 + y2 + z2 - c2t2
    For purposes of simplicity, if we drop the y and z components and go to a 2-space, let c = 1 and x measured in units of c (if we express c as 300M m/sec, the 1 unit for x would be 300,000,000 m,( we would get
    x'2 - t'2 = x2 - t2 which is equivalent to a general algebraic equation:
    x2 - t2 = a2
    In the process of that derivation, the [tex]\gamma[/tex]'s "drop out."
    This leads to an equation of symmetric hyperbola where (x,0) = ([tex]\pm[/tex] a,0)
    In terms of the general equaltion of a symmetric hyperbola there should be a constant, say
    b1 under the x and a second constant, say b2 under the t, however Einstein et al have assigned 1 for both those values.
    I have derived algebraically this equation using the Lorentz transforms - it does work out.
    How do I relate the [tex]\gamma[/tex] from the Lorentz transforms [1/[tex]\sqrt[]{(1 - v^2)/c^2}[/tex]] back to the a2? There is a relation which would change the a2 for different v's (or different [tex]\gamma[/tex] 's) but is "lost in translation." How do I get it back? This would make relating this hyperbolic equation back to hyperbolic trig functions more intuitive and thus explain the hyperbolic function matrix for the Lorentz Transformation more intuitive.
  3. Jul 22, 2010 #2
    There isn't a relationship between the gamma here, which is in the Lorentz transformation that relates the two frames, and a^2, because a^2 is an invariant (the square of the interval). If you think of vectors in the Euclidean plane, there's no relation between the length of a vector and the angle between two coordinate systems that have been rotated about the origin.
  4. Jul 22, 2010 #3
    I probably asked the question incorrectly, so I'll modify it thus:
    Clearly, the c'2t'2 - x'2 = c2t2 - x2 represents different points for different x's and t's with respect to two specific frames of reference in which, by custom the S' frame is moving at v wrt to S frame (or inertial frame which is arbitrarily assigned.)
    Thus, for a given relationship of two frames S and S' with S' moving at v, say we have the equation c2t2 - x2 = a2
    So, for whatever a is in this situation, if we have the S frame steady and another FR S" which moves at v" wrt S we will still have this new relation based on c2t2 - x2 = a2 which will be different that the original pair and the only way it can differ is in the a. It is the v that determines the value of [tex]\gamma[/tex]. This, the [tex]\gamma[/tex], call it [tex]\gamma[/tex]' for the first pair of FR's (S and S') will be different than the [tex]\gamma[/tex] for the second pair of FR's), call it [tex]\gamma[/tex]"
    There must be some relation between the a2 and the [tex]\gamma[/tex]'s.
  5. Jul 22, 2010 #4
    bapowell
    If I understand what you're doing properly, a^2 is an invariant under Lorentz transformations, i.e. we understand the hyperbola to be the orbit of the Lorentz group. The points of the hyperbola correspond to the same physical coordinates as perceived by a progression of observers each boosted infinitesimally relative to the next. So we boost (apply a Lorentz transformation with a specific \gamma) to move from one point on the hyperbola to another. By varying v from 0 to c (\gamma from 1 to infinity), we trace out the whole hyperbola.
  6. Jul 22, 2010 #5
    Over my head here.
    Is that true? Is the hyperbola traced out by different gamma's or v's (as you look at it?)
    I guess that it is traced out dependent on the a's, as the x and t values, once the gamma is calculated (it is known from the given v,) are both linear. (x' is linearly related to x and t and t' is linearly related to x and t) - kind of makes sense in the idea of a ongoing translation of axes.
    Also, makes sense that if the gamma had any play in the original equation (the a's) I gave (from Einstein, et al,) then it wouldn't dop out as we derived the 4-space equation from the Lorentx transforms.
    Let me know... is the hyperbola gamma dependent? I now don't think so. So, where does the a come from? What does it mean?
  7. Jul 22, 2010 #6
    I guess I too am a bit confused at what you're getting at, so sorry if this is worse than useless...
    I would say they represent the SAME spacetime point. Take a coordinate system, O. Take an arbitrary event in that coordinate system, E. Suppose in O its got coordinates (t, x). If you like, put a^2 = c^2t^2 - x^2 - but remember, the event is arbitrary. Then, in any other coordinate system O' (with the same origin), whatever its velocity wrt O, if the *same* event has coordinates (t' x') in O', then c^2t'^2 - x'^2 = a^2 also.
    So a is to a large part arbitrary - it just depends on the event you chose. It's the *invariance* of a, the fact that the value of this function of the coordinates of one and the same event comes out the same - even when we change our coordinate systems.
  8. Jul 22, 2010 #7
    That's good as your answer isn't useless. Remember I have no one here to bounce things off for simple concepts and, as a result, a "brain fart" actually gets posted - by me. I forgot that those transformation formulas actually referred to the same point or event but just looked at from different FR's (hence the v and gamma.) If we were face to face and I brought it up you would have corrected the BF in one instant.
    I'm just working through some basic concepts here - remember - nobody here to talk to about these, you folks are it.
    Staying within the "two-space" it looks like that Minkowski equation means that for any given point in space-time the a2 is the same irregardless of what FR you choose. This would mean a an infinite set of gamma's (or velocities of FR's)for each point as they all would satisfy the a2. Note that x's and t's for a given point do fall on a hyperbola wrt that point.
    Am I right so far?
    Remember, what is useless to you isn't so to me as I do learn and I do build on what you say...
    I never would have been able to teach medical students and interns if I thought their questions were useless.
  9. Jul 22, 2010 #8
    bapowell
    Sorry for the jargon. Each point along the hyperbola corresponds to a different value of \gamma, so it's not quite correct to say that they are independent. In fact, as the hyperbola asymptotes to the 45 degree line, the speed of the observer is asymptoting to v = c.
    The [tex]a[/tex] is the most important geometric quantity in special relativity. It is often referred to as the space-time interval, or the 'invariant length' (even though it's not necessarily a spatial length). Physically, it is the proper time. This should make sense -- an observer's proper time is, after all, independent of his state of motion.
  10. Jul 22, 2010 #9
    bapowell
    Yes! The invariance of [tex]a^2[/tex] embodies the relativity principle. It's essentially Minkowski's geometric interpretation of the Einstein postulates. The Lorentz transformations are those mathematical transformations that leave the [tex]a^2[/tex] invariant. For each [tex]a^2[/tex] there are an infinite set of x's and t's -- each of these are referring to the same physical spacetime point -- they are the coordinates of this same point as measured by different observers all moving at different speeds.
  11. Jul 22, 2010 #10
    Yes, Yes, Yes - we are home! Now, how do we get the a's. If one were given a particular x and t, one could then calculate the corresponding a, I suppose.
    What I am working is the geometric interpretation from a hyperbolic function point of view what I've posted above (see .jpg post above in post 1
    https://www.physicsforums.com/showpost.php?p=2810273&postcount=1
    on the Minkowski hyperbolic function matrix.)
  12. Jul 22, 2010 #11
    It sounds as if this isn't good enough for you. Can you give us some idea of what else you might have hoped for?
    From the geometric point of view, you might just regard the fact that the separation (the Minkowski 'distance') between two events is just a primitive geometric, coordinate-independent fact, just like the classical fact that two points of space are n metres apart, irrespective of any coordinate system.
    Not sure what you're hoping for here - can you expand? The jpg looks like a coordinate transform. The geometric approach is normally thought of as a coordinate free way of thinking about relativity. Of course, at some point, coordinates and geometry have to be related, but could you say a little more about what you're trying to do.
  13. Jul 22, 2010 #12
    The Minkowski transformation of coordinates is given by:
    [tex]\begin{bmatrix}ct'\\ x'\\ y'\\ z'\end{bmatrix}=
    \begin{bmatrix}
    \gamma & -\beta\gamma & 0 & 0\\
    -\beta\gamma & \gamma & 0 & 0\\
    0 & 0 & 1 & 0\\
    0 & 0 & 0 & 1
    \end{bmatrix}
    \begin{bmatrix}ct\\ x\\ y\\ z\end{bmatrix}[/tex]
    where [itex]\beta = v/c[/itex] and [itex]\gamma = 1/sqrt{(1-\beta^2)}[/itex]
    If we define a parameter [itex]\phi = -\ln[\gamma(1-\beta)][/itex] (sometimes called the rapidity) then it can be shown mathematically that:
    [tex]\gamma = \cosh \phi [/tex]
    and
    [tex]\beta\gamma = \sinh \phi [/tex]
    so the Minkowski transformation can also be written as:
    \begin{bmatrix}
    \cosh \phi & -\sinh \phi & 0 & 0\\
    -\sinh \phi & \cosh \phi & 0 & 0\\
    0 & 0 & 1 & 0\\
    0 & 0 & 0 & 1
    \end{bmatrix}
    and your original equation can be written as:
    [tex] a^2 = x'^2 - ct'^2 = (\cosh \phi \ x - \sinh \phi \ ct)^2 \ - (\cosh \phi \ ct - \sinh \phi \ x)^2[/tex]
    [tex]\Rightarrow a^2 = \cosh^2 \phi \ x^2 \ -2\cosh \phi \sinh \phi \ xct \ + \sinh^2 \phi \ c^2t^2 \ - \cosh^2 \phi \ c^2t^2 \ +2 \cosh \phi \sinh \phi \ xct \- \sinh^2 \phi \ x^2 [/tex]
    [tex]\Rightarrow a^2 = \cosh^2 \phi \ x^2 \ + \sinh^2 \phi \ c^2t^2 \ - \cosh^2 \phi \ c^2t^2 - \sinh^2 \phi \ x^2 [/tex]
    [tex]\Rightarrow a^2 = (\cosh^2 \phi -\sinh^2 \phi) x^2 \ + (\sinh^2 \phi - \cosh^2 \phi) c^2t^2 [/tex]
    and from http://en.wikipedia.org/wiki/Hyperbolic_function#Useful_relations"
    [tex]\Rightarrow a^2 = x^2 - c^2t^2 [/tex]
  14. Jul 22, 2010 #13
    It must be past my bedtime - I don't understand any of kev's post.
    edit: now i look like an idiot coz kev changed his post!!!!
  15. Jul 22, 2010 #14
    Actually, it must be past my bedtime. I think I made a complete hash of the first part, so I have deleted that part, while I think about it some more.
  16. Jul 22, 2010 #15
    DrGreg
    [STRIKE]Well, the second half makes sense, but I've no idea why he chose to write
    [tex]
    x^2 - c^2t^2 = c^2
    [/tex]​
    That makes no sense for an arbitrary event (t,x).[/STRIKE]
    EDIT: strike out comment that refers to material now deleted from kev's post.
  17. Jul 22, 2010 #16
    Yep, your right. See my last post. Oops!
    I think what I meant to say was something like:
    the Minkowski metric is:
    [tex]
    x^2 - c^2t^2 = c^2\tau^2
    [/tex]​
    Since both c and the proper time [itex]\tau[/itex] are both invariant under transformation to another frame, then the RHS must be invariant and so the LHS must also be invariant under transformation. Since steve effectively wrote:
    [tex]
    x^2 - c^2t^2 = a^2
    [/tex]​
    the quantity (a) must also be invariant. I am tired, so I might have made more mistakes. (Apologies in advance).
  18. Jul 23, 2010 #17
    1) Everyone of you hit on it
    [tex]
    x^2 - c^2t^2 = a^2
    [/tex]​
    \begin{bmatrix}
    0 & 0 & 1 & 0\\
    0 & 0 & 0 & 1
    \end{bmatrix}
    and
    \begin{bmatrix}
    0 & 0 & 1 & 0\\
    0 & 0 & 0 & 1
    \end{bmatrix}
    2) You must all be English as you talk of 11 PM GMT as being past your bedtime when it is 6 PM (1800) here.
    I was trying to find the relationship between a and [tex]\phi[/tex].
    I know that sinh [tex]\phi[/tex] = ct/a and cosh [tex]\phi[/tex] = x/a
    I haven't gotten to the:
    yet
    Now I have to let the dust settle, have you all agree what I just wrote was correct, and to do some problems with rapidity which is used in acceleration/deceleration situations.
    I had to learn hyperbolic geometry and I haven't seen that since college (c. 1960), so give me a bloody break (again, I am assuming you are all English, otherwise I would have chosen a few New York present participles.)
    Steve G
  19. Jul 23, 2010 #18
    Nah.. I'm the idiot. You were right that my post did not make sense the first itme around, but by the time I realised my blunder and tried to cover my tracks :tongue: it was too late and DrGreg had imortalised my mistake :blushing:
  20. Jul 23, 2010 #19
    Hey, while you boys were in la-la land, help me out...
    Is what I wrote correct?
    stevg
  21. Jul 23, 2010 #20
    My knowledge of hyperbolic functions is probably worse than yours. I have to refer to Wikipedia to remind me of the rules, but I think I have figured it out.
    [itex]x^2 - c^2t^2 = a^2 [/itex] defines (a) as imaginary number because for a particle moving at less than the speed of light [itex]x^2 < c^2t^2 [/itex]. It is better to write:
    [tex]a^2 = (c\delta t)^2 -\delta x^2 [/tex]
    [tex]a = \sqrt{(c\delta t)^2 -\delta x^2} [/tex]
    This is basically using the +--- convention for the metric, rather than the -+++ convention we were using before and I am using differentials because I want to deal with velocities rather than coordinate points.
    Now given [tex]cosh (\phi) = \pm \ \delta x/a[/tex]
    (recall that [itex]\cosh (-\phi) = \cosh (+\phi)[/itex])
    I will use the negative root from now on, because it is more convenient and define a function f such that:
    [tex]f = \cosh (\phi) = \frac{-\delta x}{a} = \frac{-\delta x}{\sqrt{c^2\delta t^2-\delta x^2}} = \frac{-\delta x/(c\delta t)}{\sqrt{1 - \delta x^2/(c\delta t)^2}} = \frac{-\beta}{\sqrt{1-\beta^2}} [/tex]
    Now using the definition
    [tex]\textrm{sech}(\phi) = \frac{1}{\cosh(\phi)} [/tex]
    I define another function (g) such that
    [tex]g = \text{sech}(\phi) = \frac{1}{f} = \frac{\sqrt{1-\beta^2}}{-\beta}[/tex]
    The inverse sech function is defined as:
    [tex]\text{asech} (g) = \pm \ln\left(\frac{1+\sqrt{1-g^2}}{g}\right)[/tex]
    [tex]\Rightarrow \phi = \pm \ln\left (\frac{1+\sqrt{1+(1-\beta^2)/\beta^2}}{(\sqrt{1-\beta^2})/(-\beta)}\ \right)[/tex]
    [tex]\Rightarrow \phi = \pm \ln\left (\frac{-\beta+\sqrt{\beta^2+(1-\beta^2)}}{\sqrt{1-\beta^2}}\ \right)[/tex]
    [tex]\Rightarrow \phi = \pm \ln\left (\frac{-\beta +1}{\sqrt{1-\beta^2}}\right)[/tex]
    [tex]\Rightarrow \phi = \pm \ln(\gamma(1-\beta))[/tex]
    You could of course take the simpler route and use the relation:
    [tex]f = \cosh(\phi) = \gamma = 1/\sqrt{1-\beta^2}[/tex]
    and work from there.
    There is also the relation:
    [tex]e^{\phi} = \cosh(\phi) + sinh(\phi) = x/a +ct/a [/tex]
    [tex]\Rightarrow \phi = \ln(x/a + ct/a) [/tex]
    that might prove useful.
    See http://en.wikipedia.org/wiki/Hyperbolic_function
    As you have probably already noticed, using rapidity because of the sinplicity of adding velocities, rather than using the relativistic addition equation, introduces a world of pain involving hyperbolic functions, exponential functions and imaginary or complex numbers to handle.
    Applogies in advance for any typos, I was just outlining some basic methods that might help.
