I The order of complex poles
  • Thread starter dyn
dyn
498
Hi.
If I look at the function ## (z^2+z-2)/(z-1)^2## it appears to have a double pole at z=1 but if I factorise the numerator I get ##z^2+z-2 = (z+2)(z-1)## and it is a simple pole.
Is it wrong to say it is a double pole ?
If I overestimate the order of the pole in this case as 2 and calculate the residue using limits and differentials I still get the correct answer. Is this always true ?
In this case the numerator was easy to factorise. If it was a complicated function involving higher powers that couldn't be factorised is it possible to say for certain what the order of the pole is just by looking at the denominator ?
Thanks
fresh_42
Mentor
Insights Author
2018 Award
11,421
7,841
This is the same as in real analysis. ##\dfrac{z^2+z-2}{(z-1)^2}## has a pole of order two, ##\dfrac{z+2}{z-1}## one of order one.
Here is how the various singularities are classified:
FactChecker
2018 Award
5,048
1,773
I would say that ##\frac {z^2+z-2}{(z-1)^2}## has a pole of order one. In defining the order of a pole of ##f(z)##, it is usual to say that ##(z-a)^nf(z)## is holomorphic and nonzero for a pole of order n.
(seehttps://en.wikipedia.org/wiki/Zeros_and_poles#Definitions )
dyn
498
Hence my confusion !
fresh_42
Mentor
Insights Author
2018 Award
11,421
7,841
But we have ##(z-1)^2f(z)=(z-1)^2\dfrac{[(z-1)(z+2)]}{(z-1)^2}##. The numerator is not defined at ##z=1## hence it cannot be equal to ##z+2##.
It is a rather academic question and of not much use: What if we combine a removable singularity with a non removable? A bit like discussing why units are not prime.
jasonRF
269
Interesting … I learned that the order of a pole of a function that is analytic in a closed region except at an isolated point, is defined as the largest negative exponent in the Laurent expansion about that point. My old copy of "A Course of Modern Analysis" by Whittaker and Watson also has this definition. Since the Laurent expansion of the function about ##z=1## is ##1 + 3/(z-1)##, the pole at ##z=1## is of order 1. Practically, I use the approach given by FactChecker.
fresh_42
Jason
fresh_42
Mentor
Insights Author
2018 Award
11,421
7,841
Yes, it's probably reasonable to cancel the quotient if there is still the same pole available, so that the same undefined points are still there.
HallsofIvy
41,698
871
For a simpler example, [itex]f(z)= \frac{z- 1}{z- 1}[/itex] has a "removable discontinuity" at z= 1, not a pole.
dyn
498
Hi.
So it seems the function has a simple pole and it is wrong to say it is a double pole. But if I overestimate the pole as a double pole and calculate the residue using limits and derivatives I get the correct answer. Does this method of calculating residues always work if the order of poles is overestimated eg. by not spotting a factorisation ?
Thanks
FactChecker
2018 Award
5,048
1,773
Yes, you do not have to factor it. The residue at ##z_0## only depends on the coefficient of the ##\frac 1{z-z_0} ## term in the Laurent series. So the effect of any numerator/denominator zeros that cancel each other will disappear.
Reactions: dyn
dyn
498
Thank you
mathwonk
10,717
893
the order of the pole is a measure of the rate of growth of the function as you approach the given point. In particular it depends only on the values of the function away from the given point, not on the specific representation of the function. Since the two representations (z^2+z-2)/(z-1)^2 and (z+2)/(z-1) define the same functional values away from z=1, the functions they represent are the same and have the same order of pole at z=1. Similarly any calculations that depend only on the values away from z=1 (such as taking limits) will give the same result.
A simpler example that illustrates the same point is to ask yourself whether the function (z-1)/(z-1) has a simple pole at z=1. Since this is (or extends continuously to) the constant function 1, it has no poles at all.
FactChecker
2018 Award
5,048
1,773
And more generally, how the function behaves in the complex plane around the pole. If it is a pole at ##z_0## of order ##n##, then the function behaves like ##\frac {b_n} {(z-z_0)^n}## near ##z_0##.
mathwonk
10,717
893
yes, for example it wraps a small circle around z0, n times around the point at infinity.
mathwonk
10,717
893
Indeed there is a topological interpretation of orders of poles. A rational function defines a continuous map from the riemann sphere to itself, and hence has a certain degree. That degree is the number of preimages of any given point, and in particular is the sum of the orders of all the poles, i.e. the number of preimages of infinity, properly counted.
Want to reply to this thread?
"The order of complex poles" You must log in or register to reply here.
Related Threads for: The order of complex poles
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
