Origin of Tension: Newton's 3rd Law or Electrostatic?
In summary, tension force in elastic springs and strings is a result of both Newton's third law and the electrostatic forces within the material itself. These forces are essentially the same thing, as almost everything we encounter is held together by electromagnetic forces. Tension only appears when the spring or string is pulled from both sides, due to the individual atoms acting as tiny springs and exerting equal and opposite forces on each other. Without anything attached to the other end, tension cannot be created.
PFuser1232
479
Does the tension force in elastic springs and strings arise inevitably as a consequence of Newton's third law? Or is it due to the electrostatic forces within the material itself? Or are both of these explanations basically the same thing?
Likes poseidon721
You've got it - they are the same thing.
Newton's 3rd law holds "regardless" of how the rope is made, or held together. But in fact almost everything you will ever encounter directly is held together by electromagnetic forces. The exceptions are atomic nuclei, hadrons, and massive objects held together by gravitation - like the Earth or moon.
Likes poseidon721
But doesn't tension appear only when the spring or string is pulled from both sides?
Likes poseidon721
Yes, but it still works that way.
You can treat each individual atom in the spring or string as a tiny spring fastened to its neighbors, and subject to Newton's third law. Tension is when these springs are stretched and compression is when those springs are compressed, and you can't do either unless you're pushing/pulling both ends of the object (if you only push/pull at one end, the forces are imbalanced and the object moves away/towards you instead of compressing/stretching). But either way, each individual atom/spring is being pushed/pulled by its neighbors, and exerting equal and opposit forces on them.
The attachments and forces within and between these 'tiny springs" are the electromagnetic forces you asked about in your original post.
Likes poseidon721 and PFuser1232
Yes. If the spring / string has no mass you cannot get any tension in it unless something is attached to the other end. You have to be either distorting something, keeping equilibrium with another external force or accelerating it.
In the same way, you can't 'push' against 'nothing'. Press-ups work as an exercise but Press-downs are useless.
Likes poseidon721
1. What is Newton's 3rd Law?
Newton's 3rd Law, also known as the Law of Action and Reaction, states that for every action, there is an equal and opposite reaction. This means that when one object exerts a force on another object, the second object will exert an equal and opposite force back on the first object.
2. What is Electrostatics?
Electrostatics is the study of electric charges at rest and the forces between them. It deals with the behavior of electrically charged particles, such as electrons and protons, and how they interact with each other.
3. How are Newton's 3rd Law and Electrostatics related to tension?
Newton's 3rd Law and Electrostatics are related to tension in the sense that both play a role in determining the forces acting on an object. In the case of tension, it is the force exerted by a stretched or compressed object, such as a rope or a spring. Both Newton's 3rd Law and Electrostatics help to explain and predict the magnitude and direction of the tension force in different situations.
4. Does Newton's 3rd Law or Electrostatics have a greater influence on tension?
It depends on the specific situation. In some cases, the tension in an object may be primarily caused by Newton's 3rd Law, such as in a tug-of-war scenario. In other cases, the tension may be mostly due to electrostatic forces, such as in the case of a charged object being suspended by an insulating string. Ultimately, both Newton's 3rd Law and Electrostatics can have significant influences on tension in different scenarios.
5. Are there any real-world examples where both Newton's 3rd Law and Electrostatics play a role in tension?
Yes, there are many real-world examples where both Newton's 3rd Law and Electrostatics are involved in determining tension. One common example is a balloon attached to a wall with a string. The tension in the string is a result of both the elastic force of the stretched string (governed by Hooke's Law) and the electrostatic force between the balloon (charged with static electricity) and the wall (with opposite charge). Another example is a suspension bridge, where the tension in the cables is due to both the weight of the bridge and the electrostatic forces between the charged particles in the cables.
  • Mechanics
  • Classical Physics
  • Mechanics
  • Mechanics
