Homework Help: The Particle in a Cube
  1. Feb 11, 2012 #1
    Problem 13.7.17 in Mathematical Methods in Physical Sciences:
    Find the wavefunction of a particle in a cube, refering to 13.3.6.
    0 < x < L, 0 < y < L, 0 < z < L
    13.3.6:
    Find the wavefunction of a particle in a square 0 < x < L, 0 < y < L. Assume V = 0.
    2. Relevant equations
    -(hbar)^2/2m * Laplacian(ψ) = i(hbar)*∂(ψ)/∂t
    3. The attempt at a solution
    Use separation of variables.
    ψ = U(x,y,z)T(t)
    Substitute UT into the equation and then divide both sides by UT to separate it into time dependent and time independent parts.
    (hbar)^2/2m * Laplacian(U) - E*U = 0
    i(hbar)*∂(ψ)/∂t = T
    Solve the time dependent ordinary differential equation for T:
    T = exp(-iEt/hbar)
    If the time independent schrodinger equation was in 1-D, it would be:
    -(hbar)^2/2m * ∂(U)/∂x = E*U
    Assume E = k^2, where k^2 = 2Em/(hbar)^2
    ∂(U)/∂x = -k^2*U
    U must be a sin or cos function in terms of U(x) but due to boundary conditions that it must be 0 at x=0 and x=L, it cannot be cos which would be nonzero at x = 0.
    U = sin(kx), k = n∏/L where n = 1,2,3...
    By analog with the 1-D case, the 3-D solutions should be:
    Ux = sin k1 * x
    Uy = sin k2 * y
    Uz = sin k3 * z
    with the constants K being all a constant (n,m,p) times ∏/L .
    The final solution is then ψ = UxUyUzT = Ʃ A(nmp)sin(k1x)sin(k2y)sin(k3z)exp(-iEt/hbar)
    Now we attempt to use initial conditions to set up a triple Fourier series and find A(nmp) where the 1-D analog would be the Fourier series
    A(n) = (2/L) * ∫(initial condition functions) sin(kx)dx from 0 to L.
    The problem does NOT give initial conditions so I have no idea how to solve the problem now. What can I possibly assume for the initial conditions such that I can obtain a solution?
  3. Feb 12, 2012 #2
    diazona
    Given that no initial conditions are specified, it's probably asking for a generic solution, which you have.
