The probability of finding R out of N bosons in one half of a volume
In summary: A,B)= (1,2) (1,4) (1,6) (3,2) (3,4) (3,6) (5,2) (5,4) (5,6) ... 9 cases number of cases = 9 probability = 9/36Ⅲ even+even (A,B)= (2,2) (2,4) (2,6) (4,2) (4,4) (4,6)
Philip Koeck
673
182
TL;DR Summary
I come up with an expression for the probability of finding R out of a total of N bosons in one half of a volume which depends on the number of available states g in half the volume as long as g is not very large compared to N and 1. I want to know whether this can be understood and explained in a common-sense way.
For the probability of finding R out of N (indistinguishable) bosons in one half of a volume with a total of 2g states (g in each half) I get the following expression:
PR = WR / WT
where WT is the number of ways of distributing N particles in the total volume:
WT = (N+2g-1)! / (N! (2g-1)!)
and WR is the number of ways of distributing R particles in one half of the volume and the remaining N-R in the other half:
WR = ((R+g-1)! (N-R+g-1)!) / (R! (g-1)! (N-R)! (g-1)!)
As long as I don't assume a large number of states g and low occupancy (g >> N), PR depends on the value of g.
My questions:
Does this seem to be correct?
Is there a common-sense way of explaining this dependence on g?
Note that at low occupancy and large g the dependence on g disappears and that for (hypothetical) distinguishable "bosons" PR doesn't depend on g in the first place, whatever the value of g is.
For fermions I can understand that PR depends on g since each fermion blocks a state and alters the situation for all other fermions so that PR must depend on g.
Can one come up with a similar explanation for indistinguishable bosons?
In case my equation is unclear I have a complete derivation here: https://www.researchgate.net/publication/336375268_Probability_of_finding_R_of_N_particles_in_one_half_of_a_volume
I could never come up with an intuitive explanation for bosons. It's of course just the Bose-Einstein-enhancement factor. Fermions are more intuitive since we deal with fermions in our daily experience, i.e., when some piece of matter occupies some space it's usually hard to put more matter into that space, and that's of course due to Pauli blocking.
The BE-enhancement is of course the bosonic analogue of P-blocking for fermions, and it just tells us that bosons like to occupy the same states, i.e., if already bosons are present other bosons of the same kind like to also occupy this space. Formally you can see this from the BE-enhancement factors ##(1+f)## in the collision term of the bosonic Boltzmann-Uehling-Uhlenbeck equation.
Now you can ask further, where this enhancement factor comes from on microscopic grounds, and the only answer is that it's a specific quantum property, discovered by Einstein in 1917, when he rederived the Planck radiation formula from a kinetic point of view: In addition to the usual absorption and induced emission contributions from classical theory he had to assume also spontaneous emission, which is specifically quantum (and in fact the only hint at the necessity of field quantization known before 1925!). In other words the most simple empirical reason for the necessity of quantizing the electromagnetic field is the phenomenon of spontaneous emission. Neither Einstein's photoelectric-effect explanation of 1905 nor Compton scattering of 1923 really needs field quantization but at lowest order perturbation theory (tree-level Feynman diagrams only) but one can derive the corresponding cross sections in the semiclassical way, i.e., quantizing the electrons only and keeping the em. field classical (semi-classical approximation of QED).
Thanks for your interesting input!
Just a few remarks from me: I realize that my model is very simplified, since I implicitly give every state the same probability to be occupied. I guess this would only be true if there is only a single energy level with 2g states.
About bosons: If there are such things as distinguishable bosons, then they wouldn't actually exhibit the same kind of enhancement as indistinguishable bosons, according to my results. For distinguishable bosons the probability doesn't depend on the number of states even if g is not big, so I would conclude that distinguishable bosons wouldn't influence each other at all.
(On the other hand they would have to be very strange, being distinguishable and able to crowd into the same state without limit.)
Only indistinguishable bosons should have this enhancement factor and therefore the probability depends on g, which becomes most visible for small values of g.
Therefore the dependence of the probability on g ought to have something to do with bosons being indistinguishable as well as being able to crowd into states.
About fermions: I just realized that I get the same expression for P for both distinguishable and indistinguishable fermions, even without approximating for large g.
It seems to me that it is fundamentally impossible to decide whether a system consists of distinguishable or indistinguishable fermions. Could that be true, or are there experiments that would answer that question?
Thanks again.
Philip
The "indistinguishability" cause the contradiction.
For example, 2 dice.
・We throw 2 dice.
・We calculate the probabilities seeing the next numerical combinations.
Combination Ⅰ: odd number and odd number
Combination Ⅱ: odd number and even number
Combination Ⅲ: even number and even number
Distinguishable 2 dice (A and B)
calculation 1
Ⅰ odd+odd
(A,B)=
( odd, odd)
number of cases = 1
probability = 1/4
Ⅱ odd+even
(A,B)=
( odd,even)
(even, odd)
number of cases = 2
probability = 1/2
Ⅲ even+even
(A,B)=
(even,even)
number of cases = 1
probability = 1/4
calculation 2
Ⅰ odd+odd
(A,B)=
(1,1) (1,3) (1,5)
(3,1) (3,3) (3,5)
(5,1) (5,3) (5,5)
number of cases = 9
probability = 1/4
Ⅱ odd+even
(A,B)=
(1,2) (1,4) (1,6)
(3,2) (3,4) (3,6)
(5,2) (5,4) (5,6)
(2,1) (2,3) (2,5)
(4,1) (4,3) (4,6)
(6,1) (6,3) (6,5)
number of cases = 18
probability = 1/2
Ⅲ even+even
(A,B)=
(2,2) (2,4) (2,6)
(4,2) (4,4) (4,6)
(6,2) (6,4) (6,6)
number of cases = 9
probability = 1/4
Calculation 2 agree with calculation 1. It is reasonable.
Indistinguishable 2 dice
calculation 3
Ⅰ odd+odd
( odd, odd)
number of cases = 1
probability = 1/3
Ⅱ odd+even
( odd,even)
number of cases = 1
probability = 1/3
Ⅲ even+even
(even,even)
number of cases = 1
probability = 1/3
calculation 4
Ⅰ odd+odd
(1,1) (1,3) (1,5)
(3,3) (3,5) (5,5)
number of cases = 6
probability = 2/7
Ⅱ odd+even
(1,2) (1,4) (1,6)
(3,2) (3,4) (3,6)
(5,2) (5,4) (5,6)
number of cases = 9
probability = 3/7
Ⅲ even+even
(2,2) (2,4) (2,6)
(4,4) (4,6) (6,6)
number of cases = 6
probability = 2/7
Calculation 4 give us the different probabilities from calculation 3.
It is contradiction !
Likes Stephen Tashi
Your example illustrates that for indistinguishable bosons the probabilities depend on the number of states associated with, for example, being even. If being even is just one state you get one set of probabilities, whereas if you associate 3 states with being even, you get different probabilities.
It's certainly interesting that indistinguishable bosons behave like that, but I don't see anything contradictory or illogical about it.
We do not have to use the character of particle to calculate the probability about the dice.
Let's suppose two indistinguishable dice whose faces with odd number are blue and with even number are red.
We roll the 2 dice many times and count the combination Ⅰ, Ⅱ, Ⅲ.
We get the next probabilities if we see the color and count them.
Ⅰ:1/3, Ⅱ:1/3, Ⅲ:1/3
But if we see the number and count them, we get next probabilities.
Ⅰ:2/7, Ⅱ:3/7, Ⅲ:2/7
Thanks for sharing this interesting paper. It fits very well into what I've been thinking about and what we've discussed so far.
I've started reading it and I get stuck at the beginning of section 3 where it states:
"For distinguishable children obeying classical statistics, statistical independence implies that the outcome of the remaining n−1 children are not affected by the outcome of the first child."
I can't make sense of that.
If there are 100 children and the most likely distribution is 50/50 to start with, then, after removing one child, the most likely distribution must be 49/50, I would think.
Even for classical children the distribution after removing one child is affected by whether you remove a boy or a girl.
Do you agree?
I think that would be true if you knew for certain that the actual distribution was going to be close to the most likely distribution. However, we don't know that. (The "most likely" outcome may not be very likely at all.)
If we assign each possible distribution its correct probability under the assumption of independent trials, the most probable distributions for the 99 remaining trials should be 49-to-50 and 50-to-49, each having the same probability.
I'm trying to make sense of this so let's take a different example.
In a large dance hall for singles there are 1000 people and the organizers know that on average there are 500 women and 500 men.
Towards the end of the evening people start leaving randomly and somebody keeps track of who is leaving. To his surprise the first 100 people to leave are all men, but there is no obvious reason for this. It seems to be just by chance.
What is the most likely distribution of man and women left in the dance hall now?
Stating the average of a random variable doesn't define its distribution. So we don't have a specific mathematical problem. For example, one possibility is that each ratio: 0 to 1000, 1 to 999, 2 to 998, ... ,1000 to 0 has the same probabiltity. Another possibility is that the ratios 101 to 899, 500 to 500, and 899 to 101 each have probability 1/3 and the other ratios have probability zero.
We can be very specific: The organizers of the dance know the exact distribution from the past. It's a Gaussian with a maximum at 500 men and 500 women. The standard deviation is 50.
Now 100 men leave early one evening. What is the most likely number of men afterwards?
I don't know what to do with a Gaussian. It's easier for me to think of a discrete distribution. Let ##f(k)= ## probability that there are ##k## total men out of 1000
Let ##g(k,m) = ## probability that there are ##k## total men out of 1000 given that ##m## randomly selected people are men.
Let ##h(m,k) = ## probability that ##m## randomly selected people are men given there are ##k## total men out of 1000.
##g(k,100) = 0 ## if ## k < 100##
if ##k \ge 100##, ##g(k,100) = h(100,k) f(k)/ ( \sum_{j=100}^{1000} h(100,j) f(j))##.
We want to find the value of ##x## that maximizes ##g(x,100)##. We can ignore the constant factor ##\sum_{j=100}^{1000} h(100,j) f(j))## and consider only the function ##h(100,x) f(x)## for ##x = 100,101,...1000####h(100,x) = (x/1000)((x-1)/1000)((x-2)/1000)...((x-99)/1000) ##
## = (x!)/ ( ( x-100)\ !1000) )##.
[Edit: No, it should be ##h(100,x) = (x/1000)((x-1)/(1000-1))((x-2)/(1000-2)...((x-99)/(1000-99))## ]The maxium of ##h(100,x) f(x)## depends on how ##h(100, x)## alters the shape of ##f(x)##.I suppose the approach of statistical physics would be to consider numbers much larger than 100 and 1000 and introduce Sterlings approximation.
Likes Philip Koeck
Maybe I'm just struggling with the language.
Here's the passage from the paper shared by Swamp Thing:
"Consider n quantum children (where n ≫ 1) in a day care center, where by the equal opportunity laws all distinct allowable gender combinations are a priori equally likely. We will define R as the ratio of quantum boys to the total number of children in the day care center.
Then
(III) What is the probability distribution of R?
(IV) One child is selected in random, which is found to be a boy. What is the probability distribution of R for the remaining children?
For distinguishable children obeying classical statistics, statistical independence implies that the outcome of the remaining n−1 children are not affected by the outcome of the first child. As a result, the probability distribution of R is a sharply peaked Gaussian around R = 1/2 for both questions (III) and (IV)."
The way I read this it means that if you randomly remove, let's say, 10 children and they all turn out to be boys, for example, then the remaining children are still most likely 50% boys and 50% girls.
This doesn't sound right to me.
Am I misunderstanding something?
I don't think this follows from the calculation presented by Stephen Tashi either, does it?
Your questions are legitimate. The text you quoted isn't clear.
I think that passage intends to discuss the distribution of ##R## under two different assumptions.
Let ##B## be the number of boys.
For "quantum" children, all combinations of boys and girls are equally likely. For example the probability of ##n## boys and ##0## girls is the same as the probability of ##n/2## boys and ##n/2## girls. So ##Pr(B=n) = Pr(B=n/2) = \frac{1}{n+1}##.
For "distinguishable children obeying classical statistics", we are to assume ##B## has a binomial distribution. So ##P(B=k) = \frac{n!}{(k!)(n-k)!}(1/2)^k(1/2)^{n-k}##.
There is the technicality that the ratio ##R = B/(n-B)## is undefined when ##B = n##. So ##R## has no conventional probability distribution. This is the type of difficulty that statistical physics manages to dance around without giving a rigorous mathematical argument.
[Edit: But the passage means to define ##R## as ##R/n## , so the Gaussian distribution of ##R## is explained by the binomial approximation for ##B##. ]
For large ##n##, a binomial distribution can be approximated by a Gaussian distribution. So I see that ##B## can be approximated by a Gaussian in the case of "classical" children. The distribution of ##R = B/(n-B)## is a different matter.
For classical children, the passage seems to rely on the fact that flipping a fair coin once doesn't affect the next n-1 independent flips of the coin. However that fact pertains to the distribution of ##B##, not ##R##.
[Edit:
Taking ##R = B/n##, and assuming ##B## is realized by ##n## independent flips of a coin, the conditional distribution of ##n-k## children would be the same as the conditional distribution of those ##n-k## children given the number of males in the previous ##k## children. So the calculations involving conditional probabilities should agree with this conclusion.]Whatever the distribution of ##R##, it makes intuitive sense that the distribution of ##R## would be about the same for ##n## as ##n-1## in the sense that if we are approximating ##R## with a continuous distribution ##f## that applies "for large ##n##", it would make little difference if we decrease ##n## by 1. That thought applies in both the case of "quantum" children and "classical" children.
Please return to the consideration about the indistinguishable two dice once again. Do you accept the contradiction?
I agree that it's very strange, but I wouldn't call it a contradiction. It's just not what we are used to.
I've had an idea concerning your calculation 4 in post #5.
If we consider a dice with n faces, where n is very large compared to 2, we would have a low occupancy situation: Only 2 dice and a large number of states they can be in.
If I am not mistaken, the probabilities for both being odd should be 1/4 and the probability for one being odd and one even should be 1/2 then, just like for distinguishable dice.
I haven't tried to work it out though.
If that is true it shows that even quantum dice behave classically ("reasonably") if the number of states is much larger than the number of dice.
For two indistinguishable dice with k even faces and k odd ones the number of odd-odd and even-even combinations is (k+1)k/2 each and the number of odd-even combinations is k2.
The probability for even-odd becomes k2/(k2 + (k+1)k).
For very large k this becomes 1/2.
Philip Koeck said:
the number of odd-odd and even-even combinations is k(k-1) each
Why isn't it just ##k^2##?
No, it's ##2 k^2##, because you have to count both odd-even and even-odd.
I've just edited my previous post and now I get what I expected to get.
You mustn't forget that the dice are supposed to be indistinguishable so the outcome 1_2 is the same as the outcome 2_1.
My question still stands: why isn't it just ##k^2## for the odd-odd and odd-even combinations?
Yes, but the representation you are using still labels the dice as "die 1" and "die 2" so you still have to count both outcomes.
One way of looking at it is that it's like a gauge symmetry: multiple "states" in your representation represent the same physical state: in this case, state "1_2" in your representation represents the same physical state as state "2_1". But your representation still has two states in it, so you have to count them both, and then apply the appropriate factors at the end to adjust the count of representation states to match the count of physical states.
PeterDonis said:
My question still stands: why isn't it just ##k^2## for the odd-odd and even-even combinations?
(I made a small correction in the quote above.)
I'm having trouble with this.
In calculation 2 of post #5 k equals 3. There we have exactly what you suggest. k2 = 9 combinations where both dice are even (or both odd) and 2k2 = 18 combinations where one is even and one is odd.
However this is valid only for distinguishable dice.
Calculation 4 is the same, but for indistinguishable dice and Kazu lists 6 combinations for odd_odd (or even_even) and 9 for even_odd.
The reason for the smaller number of combinations is that, for example, (1,2) cannot be distinguished from (2,1) for indistinguishable dice. At least that's how I understood it.
Are you saying that the listings in calculation 4 are incomplete?
Should they be the same as those in calculation 2?
Ah, I see now, got it.
What is the probability of finding R out of N bosons in one half of a volume?
The probability of finding R out of N bosons in one half of a volume can be calculated using the binomial distribution formula. This formula takes into account the total number of bosons (N), the number of bosons in one half of the volume (R), and the probability of finding a boson in one half of the volume (p). The formula is: P(R) = (N choose R) * p^R * (1-p)^(N-R).
How does the number of bosons in one half of a volume affect the probability?
The number of bosons in one half of a volume (R) directly affects the probability of finding R bosons in that half. As R increases, the probability also increases. This is because there are more bosons in that half of the volume, making it more likely to find R of them.
What is the significance of the probability of finding R out of N bosons in one half of a volume?
The probability of finding R out of N bosons in one half of a volume is significant because it can provide information about the distribution and behavior of bosons in a given system. It can also be used to make predictions and calculations in various fields, such as quantum mechanics and statistical physics.
How is this probability related to the concept of quantum statistics?
This probability is related to the concept of quantum statistics because it is used to describe the behavior and distribution of particles that follow quantum statistics, such as bosons. This probability can be used to calculate various statistical quantities, such as the average number of particles in a given volume or the probability of finding a certain number of particles in a specific state.
What are some real-world applications of this concept?
This concept has many real-world applications in fields such as physics, chemistry, and engineering. For example, it can be used to study the behavior of particles in a Bose-Einstein condensate, which has applications in quantum computing and precision measurements. It can also be used to analyze the distribution of photons in a laser, which has applications in telecommunications and medical imaging.
  • Quantum Physics
  • Quantum Physics
  • High Energy, Nuclear, Particle Physics
  • Quantum Physics
