The relation between atoms' kinetic energy and the energy levels
In summary: If the molecule is not in contact with other molecules that it can collide with, then it can emit radiation and relax to its ground state.In summary, the energy transferred during excitation of an atom can go towards both exciting the electronic levels and increasing the atom's kinetic energy. However, it is more common for the transferred energy to go towards exciting the electronic levels. The ratio between the two varies and can depend on factors such as the type of excitation and the temperature of the atom. Nonradiative vibrational transitions can occur before the excited electron relaxes to its ground state, resulting in the emission of a photon with less energy than the absorbed photon. Thermal energy can cause electronic transitions, but it would require extremely high temperatures for this
bentzy
37
Regarding the relation between atoms' kinetic energy and the energy levels of their electrons upon excitation:
In other words, what really happens when an atom is excited, either by radiation or by collisions, or otherwise ? What are the mechanisms under which the transferred energy goes to exciting the electronic levels, the atom's kinetic energy as a whole, or both ? in the latter case, which is supposedly the most common case, what's the ratio between the two (elec energy levels & atomic kinetic energy) ? Any elaboration on these aspects will be great.
Thank you, BC
since the energy transferred has to be the difference between some energy levels the difference with the energy of the radiation or the colliding particle is probably transmitted to the kinetic energy of the whole atom.
A collision can only result in a vibrational or rotational energy level transition. This is a transfer of kinetic energy. I would speculate (so don't quote me on this) that it would require extremely large amounts of thermal energy to cause an electronic transition as a result of kinetic energy transfer.
By absorbing a photon of near-UV/Vis light, a substance can undergo an electronic transition. When this happens, electrons are promoted to a higher energy level. Between electronic energy levels there are vibrational energy levels, and between vibrational energy levels there are rotational energy levels, and all are quantized. The molecule/particle must undergo nonradiative vibrational transitions in the form of collisions before its promoted electron can "relax" to its ground state. When the electron relaxes, the difference in energy between the excited and ground states is released in the form of a photon. The energy of the emitted photon is always less than the energy of the absorbed photon, due to the nonradiative transitions that occur.
I'm only an undergrad so I hope this helps!
You sure about that RedDanger? I'm nearly certain that thermal motion can cause electronic transitions. How else would hot gas emit radiation?
I'm assuming that by "hot gas" you're referring to a plasma, in which case I'm fairly certain that a large amount of thermal energy is supplied. For example, consider an ICP laser that reaches temperatures of up to 10000K. I can't think of another type of hot gas which would emit in the Vis region.
Another instance I was thinking of would be extremely hot metals, like Iron, which can turn white-hot (it's white because they're emitting Vis-region photons), or blackbody radiation. In any case, thermal energy can cause radiative emissions, but not necessarily in the Vis region of the EMR spectrum. At least, that's my understanding.
If that were true, then atoms, which only have electronic internal degrees of freedom, would never emit radiation when heated.
It can undergo nonradiative transitions, but there is no reason why it must.
1. What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion.
2. How are atoms' kinetic energy and energy levels related?
The kinetic energy of an atom is directly related to its energy levels. As an atom's energy level increases, so does its kinetic energy. This is because the higher the energy level, the faster the electrons are moving within the atom.
3. What factors affect the kinetic energy of an atom?
The kinetic energy of an atom is affected by its temperature and its mass. As temperature increases, the atoms gain more kinetic energy and move faster. Additionally, heavier atoms have more kinetic energy than lighter atoms at the same temperature.
4. How does the kinetic energy of atoms affect their behavior?
The kinetic energy of atoms plays a crucial role in determining their behavior. Atoms with higher kinetic energy are more reactive and can form chemical bonds more easily. Additionally, the kinetic energy of atoms contributes to their ability to change states of matter (e.g. from solid to liquid to gas).
5. Can the kinetic energy of atoms be measured?
Yes, the kinetic energy of atoms can be measured using various methods such as temperature, velocity, and spectroscopy. These measurements allow scientists to understand the behavior and properties of atoms in different environments.
  • Quantum Physics
  • Quantum Physics
