The role of complex conjugation in QM
  • Thread starter bunburryist
  • Tags
    Complex Qm
In summary: So if you have a real function $f(x)$ and you want to get the complex function $g(x)$, you just do $f(g(x)) = g(f(x))$. This is just a fancy way of saying that the complex number is just a real number with the addition/multiplication/conjugation of complex numbers written between the parentheses.
bunburryist
36
What is the purpose of complex conjugation in quantum physics? What is it that complex numbers allow us to do that can't be done otherwise, or at least cannot be done as easily? I understand what complex numbers are and how complex conjugation is done, yet I can't find a straightforward explanation of the role it plays and why quantum equations were framed in that context in the first place.
As simple example, at http://www4.ncsu.edu/unity/lockers/users/f/felder/public/kenny/papers/psi.html we find
"In order to keep this topic as simple as possible, we're going to start by living in a very simple universe. Our universe has only three points: x=1, x=2, and x=3. Our particle must be on exactly one of those points. It cannot be anywhere else, including in between them. Since those three points define the whole universe, the wavefunction itself is defined at all three of those points, and nowhere else. So Y is just three complex numbers, which might look something like this. " . . . and then lists the numbers. But why complex numbers?
Hi bunburryist! :smile:
I suppose the technical reason is that QM is in Hilbert space, which is a space over the complex numbers …
if it wan't in Hilbert space, it wouldn't be QM. :wink:
Perhaps the non-technical explanation is that since everything is made of waves, we need to multiply by a complex number to signify movement along the wave, and we need conjugates because combining with a conjugate is the only way to get back to real numbers, which is what probabilities have to be.
Section 3 in this article offers some motivation.
Tiny-tim, there are real Hilbert spaces, but you're of course right that QM needs a complex Hilbert space.
I found this, and it helps some as well.
http://physics.nmt.edu/~raymond/classes/ph13xbook/node93.html
In quantum mechanics the absolute square of the wave function at any point expresses the relative probability of finding the associated particle at that point. Thus, the probability of finding a particle represented by a plane wave is uniform in space. Contrast this with the relative probability associated with a sine wave: $\vert \sin (kx - \omega t) \vert^2 = \sin^2 (kx - \omega t )$. This varies from zero to one, depending on the phase of the wave. The ``waviness'' in a complex exponential plane wave resides in the phase rather than in the magnitude of the wave function.
The simplest way to think about it is to remember that a complex number is nothing more than a pair of real numbers, so the complex wavefunction is just a pair of interdependent real functions. Conjugation is just a way to get the "other" function.
1. What is complex conjugation in quantum mechanics (QM)?
Complex conjugation in QM is a mathematical operation that involves taking the complex conjugate of a number or variable. In simpler terms, it means changing the sign of the imaginary part of a complex number while keeping the real part the same. In QM, complex conjugation is used to represent the Hermitian conjugate of a quantum mechanical operator.
2. Why is complex conjugation important in QM?
Complex conjugation is important in QM because it allows us to represent the Hermitian conjugate of a quantum mechanical operator, which is essential in studying the behavior of quantum systems. It also plays a crucial role in the formulation of the Schrödinger equation, which is a fundamental equation in QM.
3. How does complex conjugation affect wave functions in QM?
In QM, complex conjugation affects wave functions by changing the sign of the imaginary part, which in turn affects the overall phase of the wave function. This change in phase can have significant implications for the behavior of quantum systems and can influence the probabilities of different outcomes.
4. Can complex conjugation change the physical properties of a quantum system?
No, complex conjugation does not change the physical properties of a quantum system. It is simply a mathematical operation that affects the phase of the wave function. The physical properties of a quantum system are determined by other factors, such as the Hamiltonian and boundary conditions.
5. Are there any real-life applications of complex conjugation in QM?
Yes, there are several real-life applications of complex conjugation in QM. One example is in quantum computing, where complex conjugation is used in the construction of quantum gates and algorithms. It is also used in various fields of physics, such as quantum field theory and quantum optics, to study the behavior of complex systems.
  • Linear and Abstract Algebra
  • Quantum Physics
  • Quantum Interpretations and Foundations
  • Quantum Physics
