The Rutherford Atom
  • Thread starter jvicens
The following questions came to my mind while I was solving a problem involving a collision of an alpha particle with a thin metal foil. Although I got the right answer (the book just listed the answer but nothing about how to get it) I still have doubts about how the real physical process takes place and doubts about the reasoning that led me to the resolution of the problem in the way I did.
The problem is about an alpha particle with an initial kinetic energy K = 5MeV, which hits a thin metal foil with Z=50 and gets scattered 180 degrees afterwards. The question is: what must have been the alpha particle’s distance of closest approach to the scattering nucleus?
They way I approached the problem was by thinking that the alpha particle could have gotten its energy after been accelerated through a voltage difference of 2.5x10^6 Volts (2e x 2.5x10^6 = 5MeV). If the alpha particle is to bounce back after hitting the thin metal foil then it is necessary that as the alpha particle gets closer to the nucleus it "sees" or "feels" at least a similar voltage through which it was accelerated in order to balance its initial kinetic energy. In this case is 5MeV. The voltage the alpha particle’s sees will depend on how close it gets to the nucleus of one particular atom in the thin metal foil and of course depends on the electrical charge of that nucleus.
The electrical potential created by the nucleus (Z=50) is:
V = K x q / d
V = (9x10^9) x (50 x 1.6x10^-19) / d
and it has to be equal to
(2.5x10^6) = (9x10^9) x (50 x 1.6x10^-19) / d
solving for "d" I got 2.88x10^-14 meters. The book says 2.9x10^-14 meters.
The questions I have are:
1. Is the alpha particle bouncing back just entirely because of electric field repulsion or there is also a real physical collision (contact) between the alpha particle and the nucleus?
2. The problem was asking for "the distance of closest approach between the alpha particle and the nucleus to have it scattering 180 degrees". I was thinking why is this distance the closest distance? I thought the reason why this distance is the “closest” is because the conservation of energy will not allow the alpha particle to get any closer than 2.9x10^-14 meters from the nucleus because beyond that point the electrical potential energy will be equivalent to more than 5MeV and this could not be. Is this correct?
3. Assuming the alpha particle does not lose energy on other collisions, an alpha particle with kinetic energy of 5MeV will always reach 2.9x10^-14 meters from this nucleus (Z=50) and will not get any closer. Is this statement correct?
4. If the scattering angle were not 180 degrees but, for example, 165 degrees, how would have this changed the answer of the problem? My thoughts are that this change in scattering angle will definitely affect momentum calculations but not necessary kinetic energy of the alpha particle after the collision. I suppose the velocity of the scattered alpha particle could have had the same magnitude in both cases, 180 degrees and 165 degrees. The same velocity after the collision means same kinetic energy after the collision and that would mean that in both cases the particles have reached the same distance from the scattering nucleus, in this case 2.9x10^-14 meters. The scattering deviation angle depends on the distance between the alpha particle's straight trajectory and a parallel line to it passing through the nucleus center. Again my question is whether these thoughts are correct or not.
From what I have read, Rutherford worked out a formula for the expected distribution in scattering angles using classical dynamics. The answer that Rutherford found showed dependence on the charge to mass ratio of the alpha particle and on the charge of the nucleus, Ze. Where can I find a paper/summary/analysis of how Rutherford arrived to this conclusion?
Gokul43201
Staff Emeritus
"Real physical contact" is just an artifact of electrostatic repulsion. All mechanical (action-reaction) forces are just macroscopic manifestations of electrostatic forces.
Yes, that's right (the idea; I haven't checked the number). Essentially, the total energy (KE + PE) is conserved. At the point of closest approach, the velocity and hence, the KE must become zero. So, all the initial energy goes into the electrostatic PE. This is the same as saying that the KE can not be negative (classically), so the PE can not exceed to total initial energy (=5 MeV).
Yes, it can't get closer. But does it always have to get this close ?
No, that's not right. As in the earlier part, you must apply energy conservation correctly. In the case of the 180 degree rebound, the velovity at the point of closest approach is zero. Is this also the case will some other angle ?
...as well as the mass, charge and velocity of the particles used. For the case of alpha particles, tha mass and charge are fixed - not the velocity.
Here's what Rutherford knew about the nature of the alpha particles : http://nobelprize.org/chemistry/laureates/1908/rutherford-lecture.html
More references :
The Existence of Bodies Smaller than Atoms
Trans Roy Soc of Canada 8 79-86, 1902
The Retardation of the Velocity of the Alpha Particles in Passing Through Matter , Phil Mag ser 6, xi 553-4, 1906
The Charge and Nature of the Alpha Particle (With H Geiger), Proc Roy Soc A81 162-73, 1908
The Scattering of the Alpha and Beta Rays and the Structure of the Atom Proceedings of the Manchester Literary and Philosphical Soc IV, 55 18-20, 1911
OR
The Scattering of Alpha and Beta Particles by Matter and the Structure of the Atom Phil Mag ser 6, xxi 669-88, 1911
and of course,
The Structure of the Atom Nature 92 423, 1913
dextercioby
Insights Author
12,928
504
Incidentally,for head-on collision,but with different scattering angle,indeed,one has to consider the conservation of linear momentum as well.But if the collision is not head-on,one has to consider the conservation of angular momentum,too.
Considering the most general case (arbitrary angle scattering off repulsive Coulomb potential for non head-on collisions),one can recover Rutherford's original calculations.
Daniel.
P.S.I've been taught this in the "Atom and Molecule's Physics" course back in the IInd year.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
