The specific heat
  • Thread starter STAii
STAii
333
Hello.
The other day i couldn't sleep, so i started to think.
After some long thinking, i reached a concludion (i was half sleep anyway !).
I reached the conclusion that the specific heat of any matter is supposed to raise as the temprature of the body raises.
So, am i kind of right ?
Thank you :smile:
Answers and Replies
Mike H
506
Does specific heat capacity vary with temperature? Yes. The values usually start to level off once you reach room temperature (there's often an exponential-like rise from very cold temperatures until you reach room temperature for a wide variety of substances) which allows most processes of general interest (e.g. in chemistry & biology) to be treated with a constant specific heat capacity.
Artman
1,509
31
Specific heat is a measure of how much heat it takes to raise the temperature of something 1 degree Celsius.
I imagine it would be true that as the object reaches a higher temperature it would require more heat to raise it's temperature. This is probably due to the fact that the atoms are farther apart when the substance is hot. Generally speaking, solids have lower specific heat than liquids (ice is about half that of water).
Likes Ravi Singh choudhary
STAii
333
I always had a problem with the scientifical english terms, but i remember that the specific heat is "the amount of heat energy needed to raise 1 kg of a certain matter 1 celsius degree.
Anyway, my explanation of this has nothing to do with volume (i will write it later after i see some replies).
Suggested for: The specific heat
  • Last Post
  • Last Post
  • Last Post
  • Last Post
