Calculating Temperature Outside with Speed of Sound
In summary, the conversation was about a lab where the participants used the speed of sound to calculate the temperature outside. They hit two blocks together and timed the echoes to determine the speed of sound. However, there was confusion about the distance and time measurements, which led to incorrect calculations. It was eventually discovered that the time needed to be divided by two due to the pauses between hits, resulting in the correct temperature calculation.
xRadio
60
Alright we did a lab using the speed of sound we were suppose to able to calculate the temperature outside.
v = 332 +0.6T
So this is what we did, one person hit two blocks together twenty times at an equal pace. The timers start when the person first hits the block together and stops when the last echo is heard.
The distance from the wall and back is 200m
So the times we got were 23.40s, 23.28s
Then I calculated the average total time and average time for each echo cycle. Which is 1.167s
So Speed = Distance / Time for each cycle Right?
Speed = 200m/1.167s?
If I do this, I end up with a negative temperature.
So then did this, Speed = Distance/ Half of the time for each cycle.
Speed = 200m/0.5835s
By doing this I got the right temperature.
Can anyone explain to me why I needed to divide the time for each cycle by two?
If your time is from when you clap to when you hear the echo, the distance is actually 400m since the sound is making a round trip. (Or half the total time to go 200 m)
What do you mean its making a round trip?
Do you mean like its 400m to the wall and back?
Because the distance to the wall is 100m.
Hmmm, I misread part of your post, I thought the 200 m was the distance to the wall only. Sorry about that.
Yea its no problem. But do you understand why the time would be divided by two or why the distance would be multiplied by two?
helluva way to measure temperature if you ask me:tongue:
But something is amiss, 200/1.17=170m/s, exactly 1/2 the speed of sound. I think maybe something in the methods used which caused the receiver to hear an earlier echo than the one triggered by the last event? I would think cleaner, tho less efficient and I understand the reasoning I believe, but led to big error anyway, single trials x 20..
Huh? =/ lol sorry, I still don't understand why its like this.
Just to check, are you SURE the distance to the wall and back was 200 m??
I think what denverdoc is saying is that it could be due to error in measurement, like stopping the timer too soon, or maybe just in the reaction time of the person working the timer.
The notion I suppose is a training effect and cancels sone randomness from the human side, in other words observations 10-20 show less
variability than 1-10. Thats the strength of the experiment. The weakness is hearing slap/echo/slap/echo and avoiding echo/slap error. In plain english after ten trials are the timekepers hearing the sound fom an earlier echo?
Yup I'm sure the distance there and back is 200m.
No I don't think the time keepers are hearing the sound from an earlier echo, it was pretty clear 20 echoes were heard.
i didn't buy it either. especially if it was just an aggregate time. Hage is right, had to have been 50 meters away. 100m is like a football field.
alright I found out why it is now, by hitting it at an equal pace, there is a pause between each echo and the next hit.
Hit-(speed moves)-Echo-(pause to create equal pace)-Hit-(speed moves)-Echo-(pause to create equal pace)
So the 1.167s is the time between the hits. Therefore I had to divide it by two.
good grief, why didn't i see that, thanks for the update.
What is the equation for calculating temperature outside using the speed of sound?
The equation is: Temperature (in Celsius) = 0.6 x (Speed of Sound in meters per second) - 36.5.
How accurate is this method of calculating temperature?
This method is fairly accurate, with an error margin of about 1-2 degrees Celsius. However, it can be affected by factors such as humidity and wind.
What is the concept behind using the speed of sound to calculate temperature?
The speed of sound is directly related to temperature, as the molecules in the air move faster at higher temperatures, resulting in a faster speed of sound. By measuring the speed of sound and using a conversion factor, we can determine the temperature.
What are some potential limitations of using this method?
As mentioned before, this method can be affected by humidity, wind, and other environmental factors. Additionally, it requires a relatively precise measurement of the speed of sound, which may not be readily available in all locations. It also assumes a standard atmospheric pressure.
Can this method be used to calculate temperature in any location?
This method is most accurate in open areas with minimal obstructions, as sound waves can be distorted by buildings and other structures. It also works best in areas with consistent atmospheric conditions. In general, it is most suitable for outdoor environments.
