• Support PF! Buy your school textbooks, materials and every day products Here!
Theoretical Line
  • Thread starter Touchme
I have a lab question that states "does your experimental value agree with the theoretical line for projectile motion?" What is a theoretical line and how do I compare these value.
I thought a theoretical line is x=V(sq.root(2h/g)), but im not sure.
Answers and Replies
radou
3,115
What value did you measure?
i measured the horizontal distance and and horizontal velocity.
radou
3,115
So, which is the equation of the displacement in the x-direction? Which is the equation of the horizontal component of velocity? Use these equations to compare your test results with the 'theoretical' values.
The problem is that the theoretical values are not given. All I have is the equation and a plot of my experimental values. How do I determine the theoretical line that I need to compare my values?
radou
3,115
Well, I guess you have a plot of your experimental values dependent on time, right? So, just plug the 'times' into the 'theoretical' equations and compare the results. I hope I'm not missing something big here.
It is not a plot dependent on time. The plot is x (distance) vs. horizontal velocity. I plugged the values into the equation above and compared the values. But, is there a way I can draw or determine the theoretical line?
radou
3,115
Horizontal velocity is constant and equals vx = v0*cosA, where v0 is the initial velocity and A is its angle. Since it is constant during time, it is represented as a horizontal line in a t-vx coordinate system. Maybe this is what you mean by 'theoretical' line.
how is it represented in a X vs Vx coordinate system?
radou
3,115
The same. vx is constant for every point x.
hmm.. i think i got it thanks
Related Threads on Theoretical Line
  • Last Post
  • Last Post
  • Last Post
  • Last Post
38K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
