The Role of Theories, Models, and Laws in the Scientific Process
In summary, theories, models, and laws all play important roles in the scientific process. A model is a simplified representation of reality that is used to explain observations, while a theory is a network of interrelated hypotheses that can be used to predict and understand a wide range of phenomena. Laws can be either universally valid statements or conventional names, and they can also be part of a theory. Models are used in both theories and laws, and they are always approximate since it is impossible to have perfect knowledge or accuracy. Our current models are simplified versions of reality, but they are accurate enough to be useful. Examples of models and theories include the Bohr and electron cloud models of an electron, which are associated with the theory of quantum mechanics. The
Frasch
What role do theories, models, and laws play in the scientific process? Is there a clear dividing line between a theory and a law? Are models used in both theories and laws? All theories and laws? Do our best current models perfectly represent reality to the best of our knowledge, or are they a simplified version of what we understand to be reality so that they can be used as tools to predict future events?
Here are some ways to think about these terms. They are not the only ways, but I have found them helpful:
Model - A simplified picture of a part of reality, used to explain some observation or set of observations. Think of a map. A map that represents absolutely everything would be too complex and probably not very useful. Simplicity can aid understanding. Accounting for more and more of real-world complexity if often in tension with this goal.
Theory - A network of interrelated and very successful hypotheses, which can be used to predict and understand a wide variety of phenomena. The theory of evolution is a good example. Plate tectonics is another.
Law is sometimes used to mean a statement that is universally valid, but sometimes it is just a conventional name, as in Ohm's law. Arguably the most fundamental laws of physics are of the former type!
By these definitions, theories can contain or give rise to many models. Evolution, for example, acts as a framework that can be used to generate models. Newtonian mechanics, likewise, is a framework that can be used to generate models.
Likes rootone and Frasch
Must models always be a simplified version of our perception of reality? Bohr's atomic model for example isn't entirely correct. It is only approximately accurate. Are all models simplified and approximate in this way? Is our current model, the quantum mechanical model simplified in this way?
It must be assumed that all models are simplified versions of reality, since it is inherrently impossible to prove that they are totally accurate.
But are there any known simplifications with our current models? Also are there laws or theories that we don't use models to understand?
"All models are wrong, but some are useful." - George Box
Yes, every single model is approximate, and even if it wasn't, our measurements are only approximate. The question is: is my model accurate enough where it can be applied? If the answer is yes, then you've got a good model.
Likes rootone
But are our best and most current models only approximate because we don't have perfect knowledge of how things really work, or is it also because we have simplified the models and made them less accurate and more approximate in order for them to be useful? Also, what are some examples of models and theories? I mentioned the Bohr and electron cloud models of an electron, what theory is associated with them? What models are associated with the Big Bang theory?
Frasch said:
But are our best and most current models only approximate because we don't have perfect knowledge of how things really work...
Right. Since it is impossible to test everything and impossible to have perfect accuracy, it is impossible to know for sure if the models are 100% accurate.
No, we'd certainly not intentionally do that. We may simplify things for use when the accuracy isn't needed, but for learning how the universe works, scientists make things as complex as needed.
Theories and their associate mathematical models generally don't have different names, unless the theory is sort of a meta-theory like the Big Bang, which incorporates several theories (such as General Relativity).
Likes Frasch
If we ever did find out how things "really work", how would we know it? (as opposed to merely finding another approximate model?)
Possibly not completely on point, but we continue to use the model of Newtonian mechanics because it is simple in spite of the fact that we have more accurate models (special and general relativity) available. Meteorologists use simplified models of the Coriolis force (assuming that it applies only tangential to the Earth's surface) in order to simplify their calculations. The vertical component is dwarfed by the effect of gravity and buoyancy. In fluid mechanics, a number of simplifications are possible. For instance, the assumption of incompressable flow or ideal gasses. When analyzing a spring, we might use Hooke's law even though experiment would likely show it not to be completely accurate.
Likes rootone
I understand that we can never be sure that we have a perfect model, I'm more curious about the models that we use that have errors that we are aware of. Something like hooke's law for example. If I'm correct it's an approximate model that we still use. Is that only because it's an old model that is still useful, or was it known to be an approximation when it was discovered? Also, is there any modeling going on in laws such as the conservation of momentum?
Most theories are established when the data on them is still pretty thin, so their limitations are not known. The limitations (if any) are only discovered later.
However, both can be true: some are used that have known real inaccuracies and sometimes it is just that the situation is more complicated than the model takes into account. A real spring doesn't follow Hooke's law very closely not because of a problem with Hooke's law, but rather because of issues with the spring (geometry, mostly) that add other components to the motion or just make it hard to analyze properly. When scientists are testing a theory, they do their best to design an experiment that eliminates such issues and focuses just on what they are trying to test.
Now, a theory can cross that bridge or even be on either side. Newton's gravity, for example. It is still perfectly accurate (to within the limit of our ability to measure) in certain situations (no motion), but it tends to be used in a lot of situations where it is known to be inaccurate, as long as the known inaccuracy is too small to matter.
All physics laws have models. All mathematical statements in physics are models. So yes. M1V1+M2V2=M3V3, for example.
If the plan is to build a bridge then using Newton's mechanics is fine for that purpose, even though we know it isn't fully accurate.
Using relativity would not result in a better bridge, and would most likely give the construction engineers an aweful headache.
Likes russ_watters
1. What is the difference between a theory and a model?
A theory is a well-supported explanation of a natural phenomenon, while a model is a simplified representation of a complex system. Theories are based on extensive research and evidence, while models are created to help us understand and make predictions about the real world.
2. How are laws different from theories?
Laws are statements that describe a natural phenomenon, while theories explain why and how a phenomenon occurs. Laws are often simpler and more general than theories, and they can be derived from theories. Additionally, laws are considered to be universally true, while theories may be modified or revised as new evidence is discovered.
3. Can a theory become a law?
No, a theory cannot become a law. A theory and a law serve different purposes in the scientific community. A theory explains a natural phenomenon, while a law describes it. A theory can be supported or modified by new evidence, while a law is considered to be universally true.
4. How are theories and models used in science?
Theories and models are two important tools in the scientific process. Theories help scientists understand and explain natural phenomena, while models allow them to make predictions and test their theories. Both are constantly being tested and refined as new evidence is discovered, leading to a deeper understanding of the natural world.
5. Are all scientific theories proven?
No, not all scientific theories are proven. Theories are based on extensive research and evidence, but they are constantly being tested and refined as new evidence is discovered. It is important to note that a theory can never be proven true, but it can be supported by a vast amount of evidence and withstand rigorous testing.
  • Classical Physics
  • Beyond the Standard Models
  • Quantum Interpretations and Foundations
  • Other Physics Topics
  • STEM Academic Advising
