Understanding the Variability of EMF in Real-Life Batteries
  • Thread starter Tanishq Nandan
  • Tags
    Life Theory
In summary, the potential difference across the emf of an ideal battery is constant, but for real life batteries with internal resistance, the potential difference changes as soon as a current flows through it. This is because the current flows through the internal resistance and causes a potential drop. The internal resistance of a battery can also change with use and temperature, making it difficult to accurately measure the remaining energy in the battery.
Tanishq Nandan
122
Member advised to use the homework template for posts in the homework sections of PF.
Hey,
My question isn't exactly a problem,it's just a doubt which occurred in my mind,while studying current electricity.The potential difference across the emf of an ideal battery is considered to be constant,whereas if the battery has an internal resistance (the case for all real life batteries),the potential difference across it's terminals changes as soon as a current flows through it.
What is the exact reason for this??
Tanishq Nandan said:
Hey,
The current flows through the internal resistance, and causes potential drop across it.
Oo..that simple?
K,thanks
Yes that simple.
Just for info... The internal resistance isn't always constant. Sometimes a used AA cell will read 1.2-1.4 V on a volt meter even though it's nearly empty. But if you try and draw any significant current from it the voltage falls much further than it would if the battery was new/full. The internal resistance has increased as the cell was used. The internal resistance of a cell can also vary with cell temperature. All this means that measuring the voltage of a cell isn't necessarily a good indication of how much energy is left in it.
Likes Tanishq Nandan
1. What is the theory behind real life emfs?
The theory behind real life electromagnetic fields (EMFs) is based on the principles of electromagnetism, which describe the relationship between electricity and magnetism. EMFs are created when an electric current flows through a conductor, such as a wire, and generate a magnetic field around the conductor. This magnetic field can then interact with other objects and produce various effects, such as inducing electric currents in nearby conductors or exerting a force on magnetic materials.
2. What are the sources of real life emfs?
Real life EMFs can come from a variety of sources, both natural and man-made. Some common sources include power lines, household appliances, cell phones, Wi-Fi routers, and radio and television signals. The strength and type of EMF produced by these sources can vary depending on factors such as the amount of electricity flowing, the distance from the source, and the frequency of the signal.
3. Are real life emfs harmful to human health?
This is a highly debated topic and there is no conclusive evidence that real life EMFs have a significant impact on human health. While some studies have suggested a potential link between EMF exposure and health issues such as cancer, the majority of scientific research has not found a direct causation. However, it is always recommended to limit exposure to EMFs and follow safety guidelines, especially for individuals who are more sensitive or have pre-existing health conditions.
4. How can we measure real life emfs?
EMFs can be measured using specialized equipment such as a Gaussmeter or an EMF meter. These devices can detect and measure the strength and frequency of EMFs in a given area. However, the accuracy of these measurements can be affected by factors such as the positioning of the device, the type of EMF being measured, and the presence of other nearby sources.
5. Can we protect ourselves from real life emfs?
There are various ways to limit exposure to real life EMFs, such as keeping a safe distance from sources, using protective shielding, and limiting the use of electronic devices. However, it is important to note that EMFs are a natural part of our environment and completely avoiding them is nearly impossible. It is best to educate ourselves about EMFs and take necessary precautions to minimize exposure while maintaining a balance in our daily lives.
