Exploring the Role of Electron Spin in Quantum Mechanics
In summary, the electron has intrinsic spin with an angular momentum. This spin is invoked to explain the splitting of beams in Stern Gerlach experiments. The Dirac equation predicts the existence of spin, but does not derive it from theory.
foobar
QM texts explain electron spin as an intrinsic spin with intrinsic angular momentum of electron.
And this theory predicts (or postdicts maybe?) splitting of silver or hydrogen atom or electron beams in Stern Gerlach experiments.
a few questions:
1) intrinsic angular momentum with its magnetic moment is invoked to explain the beam splitting in a nonuniform magnetic field. But many electrons in a sivler atom also have non zero angular momentum and associated magnetic moment. Why does this not also cause beam splitting in SG experiment into more than two beams ??
2) Does QED predict electron spin?
3) Does the Dirac equation predict electron spin or handle it, and how or any link to an explanation would be good.
tia
what is the spin of a 'lone pair'?
QED and Dirac eq. are based on the existence of spin, spin is found experimentally before one developed theory.
In other words, QED and the Dirac equation do not derive or predict the existence of spin, but assume it as an empirical fact.
Dirac wanted an equation for describing the quantum-relativistic motion of electron. He found that for obtaining an hamiltonian linear in mass and momentum he must working in (at least) 4-dimensional space. Those additional dimensions provide the existence of spin and antimatter.
Althought spin was alreay known (and so surely it had to appear in the equation) there is littley logically-derived in the formalism.
Ll.
Spin was already formulated by W. Pauli before Dirac did this equation, the thing Dirac did was to extend Paulis eq. into special relativity, and hence he got the negative energy solution, which he postulated were the existence of antimatter.
After Dirac italian Maiorana has derive a Dirac like equation for the photon with spin 1.
If you know the experiment results you can slant almost every theory to these results, remember Ptolemeus Universe :)
i think you are right, thanks for precisation.
Ll.
Ll.
also recall the relation between Dirac's gamma matrices and Paulis spin matrices.
What is electron spin?
Electron spin is an intrinsic property of electrons, meaning it is a fundamental characteristic of electrons that cannot be changed. Spin is a type of angular momentum that describes the rotation of an electron around its own axis.
How is electron spin related to magnetism?
Electron spin is directly related to magnetism. The spinning of an electron creates a magnetic moment, which is a tiny magnetic field. The alignment of these magnetic moments in a material determines its overall magnetic properties.
What is the significance of the Pauli exclusion principle in the theory of electron spin?
The Pauli exclusion principle states that no two electrons in an atom can have the same set of quantum numbers. This principle is important in the theory of electron spin because it explains why electrons with opposite spins are able to occupy the same orbital.
How does electron spin contribute to the structure of atoms?
The electron spin is a crucial factor in determining the structure and stability of atoms. The arrangement of electrons in an atom is determined by their spin, which affects their energy levels and thus the overall stability of the atom.
Can electron spin be observed or measured?
Yes, electron spin can be observed and measured using various techniques such as spectroscopy, magnetic resonance imaging, and electron paramagnetic resonance. These methods allow scientists to study the behavior and properties of electrons with different spin states.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
