Thermal conductivity of a thin film
The discussion focuses on measuring the thermal conductivity of thin films, specifically comparing it to nanowires. The key formula for calculating thermal conductivity (k) is provided as $$k = \frac{Q}{A\Delta T}$$, where Q represents heat flow, A is the cross-sectional area, and ΔT is the temperature gradient. To accurately measure thermal conductivity in thin films, one must assess the temperature gradient using thermocouples or other temperature sensors, or by evaluating the power dissipated in the film.
  • Understanding of thermal conductivity principles
  • Familiarity with temperature measurement techniques, such as thermocouples
  • Knowledge of heat transfer equations
  • Basic concepts of thin film physics
  • Research advanced techniques for measuring thermal conductivity in thin films
  • Explore the use of thermocouples for temperature gradient measurement
  • Study the impact of geometry on thermal conductivity in nanostructures
  • Learn about power dissipation methods in thin films
Researchers, materials scientists, and engineers involved in thermal management and characterization of thin films and nanostructures.
nanoboyAhmet
The problem is given.
I tried to solve the question as if there is a nanowire between two reservoirs and got an answer. But I don't know what should I do to measure thermal conductivity in a thin film.
My formula for k in a nanowire was independent from geometry and material, just dependent to temperature. So if I say, the thin film and nanowire conductivities are the same, would this reasoning be valid?
To measure thermal conductivity of a thin film, you will need to measure the temperature gradient across the film and then calculate the thermal conductivity from that. This can be done by either measuring the temperature directly with thermocouples or with other temperature sensors, or by measuring the power dissipated in the thin film and then calculating the temperature gradient from that. Once you have the temperature gradient, you can use the formula $$k = \frac{Q}{A\Delta T}$$ where Q is the heat flow, A is the cross-sectional area of the thin film, and ΔT is the temperature gradient.
  • · Replies 0 ·
  • · Replies 0 ·
