Thermal conductivity twice that of brass
In summary, the thermal conductivities of Al and brass are given as twice and one times, respectively. Two rods of equal lengths and radii (one Al and one brass) are joined together end to end with excellent thermal contact. The free end of the brass rod is maintained at 0 degrees C and the Al free end is heated to 200 degrees C. If no heat escapes from the sides of the rods, the temperature at the interface between the two metals can be calculated using the rate of energy transfer equation, where the thermal conductivities of Al and brass are used to find the steady-state temperature at the interface.
Dx
Hiya!
The thermal conductivity al Al is twice that of brass. Two rods (1 Al and the other brass) are joined together end to end in excellent thermal contact. The rods are of equal lengths and radii. The free end of the brass rod is maintained at 0 degrees C and the Al free end is heated to 200 degree C. If no heat escapes from the sides of the rods, what is the temperatur at the interface between the two metals.
This sounds somewhat like a difference equation problem and i think i must find the thermal conductivity of Al and brass which i think one is .11 and the other .84 or something, ill have to recheck it. My question is what formula do i use to solve for this?
Thanks!
Dx :wink:
At what time? That bit of information is crucial!
A difference equation? No, you are going to run into a partial differential equation, namely the heat equation.
You know it doesn't say, interesting? It must be a trick question then.
A difference equation? No, you are going to run into a partial differential equation[/i], namely the heat equation.
Your right, a partial.
Thanks!
Dx :wink:
Yes, the heat equation is (for constant conductivity):
cρ∂T/∂t=κ[nab]2T
Since there is a time dependence, we need to know something about that.
Go for the time independent solution. If both ends of the system are held at a constant temp a non time dependent solution will develop.
start with
dQ/dt = - kAdT/dx
A = cross sectional area
k = thermal conductivity
This holds in each material. Further, since no heat is lost from the system, we have dQ1/dt = dQ2/dt, also given in the problem A1 = A2
let dT/dx = (T2 - T1)/L in each material
You need to draw a picture of the sytem, define T1, T2 & T3 for your system, recall that the boundry will be a common point. Assemble the pieces of the puzzel I have presented and do some algebra.
Don't look up the thermal conductivities. In this problem you are given that "the thermal conductivity of Al is twice that of brass" (which is approximately correct) so that is the relationship you should use to solve it (i.e. let k=thermal conductivity of brass and 2k=thermal conductivity of Al).
I don't disagree with Integral, but you may find this easier (it is based on exactly the same approach as Integral's answer):
Assuming that the temperature gradient is uniform,
P (the rate of energy transfer) is proportional to the cross-sectional area A and the temperature difference, and inversely proportional to the length.
k, the thermal conductivity, is the proportionality constant, so (for EACH rod):
P = kA(T2 - T1)/L
Once a steady state is reached, the rate of heat transfer through both rods will be equal.
Using this, you should be able to calculate the steady-state temperature at the interface.
1. What is thermal conductivity?
Thermal conductivity is a measure of how well a material can transfer heat. It is the rate at which heat energy is conducted through a material per unit area, per unit thickness, and per unit temperature difference.
2. What is the thermal conductivity of brass?
The thermal conductivity of brass varies depending on the composition and temperature, but on average it is around 109 watts per meter-kelvin (W/mK).
3. How does thermal conductivity twice that of brass affect heat transfer?
A material with thermal conductivity twice that of brass will transfer heat more efficiently and at a faster rate. This means that it will be able to conduct heat away from a source or distribute heat more effectively.
4. What are some examples of materials with thermal conductivity twice that of brass?
Some examples of materials with thermal conductivity twice that of brass include copper, silver, and diamond. These materials are often used in heat sinks, heat exchangers, and other applications that require efficient heat transfer.
5. How is thermal conductivity twice that of brass beneficial?
Having a material with thermal conductivity twice that of brass can be beneficial in many ways. It can improve the efficiency of heating and cooling systems, increase the lifespan of electronic devices, and help prevent overheating in industrial processes.
16K
14K
