Thermal effusion problem - typical qualifier
In summary, thermal effusion is the transfer of heat between two objects in direct contact with each other, due to the movement of particles from the hotter object to the cooler object. A typical qualifier in a thermal effusion problem is a specific condition or parameter given in the problem. Thermal effusion is calculated using the formula Q = hAΔT, and factors that affect it include temperature difference, heat transfer coefficient, material properties, contact area, and duration. It differs from thermal conduction in that it only occurs with direct contact and is a surface phenomenon, while thermal conduction can occur without direct contact and throughout the object's volume.
StarTiger
Part a: A thin walled vessel of volume V, kept at constant temperature T, contains a gas which slowly leaks through a small hole of area A. The outside pressure is negligible (assume zero), so no leakage back into the vessel is possible. Find an expression for the pressure "inside the gas" as a function of time.
Part b: Repeat the calculation for an ideal gas, this time "without correct Boltzmann counting", ie assume that z(T,V,N) = Z^N.
Show that entropy is not extensive.
Statistical physics.
I'm fairly sure I've solved part A, but I am a bit stumped on how to approach B.
Perhaps I tackled A using the wrong model and that's what has left me stumped.
For A,
I took dN/dt = - PA / ((2*pi*m*k*T)^(1/2)) (from flux expression)
and dN = d(PV/kT) =(V/kT) dP
so -DP/dt=kT/V[(-AP/(2pi*mkT)^1/2]
so dP/dt = -kTAP/(V(2pi*mkT)^.5)
and from here I solve for P(t).
Set -V(2pi*mkT)^.5)/kTA equal to tau. See that dP=-1/tau dt
then get P(t)=P_o e^(-t/tau).
So I think this is all right, but how to tackle the second part is a bit beyond my current understanding. Any tips? Insights? Recommendations? Have I blown something already?
Thank you for your interesting question. I appreciate your effort in solving part A and your curiosity about part B. Let me offer some insights and tips that may help you tackle the second part of the problem.
First, let's review your solution for part A. Your approach is correct, and you have correctly derived the differential equation for the pressure as a function of time. Solving this equation, you have obtained the expression for the pressure as a function of time, which is also correct. Well done!
Now, let's move on to part B. In this part, you are asked to repeat the calculation for an ideal gas, but without using the correct Boltzmann counting. This means that you should use the expression z(T,V,N) = Z^N, where Z is the partition function for a single particle. This assumption is not physically correct, as it does not take into account the fact that each particle in the gas has its own distinct energy levels. However, it will allow us to see the difference in the results and understand why entropy is not extensive.
To solve this part, you can follow a similar approach as in part A. Start by writing the differential equation for dN/dt, but this time using the incorrect Boltzmann counting. You will end up with a different expression for dP/dt, which you can then solve to obtain the pressure as a function of time.
Once you have the expression for pressure as a function of time, you can calculate the entropy as S = Nkln(z), where z is the incorrect partition function z(T,V,N) = Z^N. Then, you can compare this result with the correct expression for entropy, which is S = Nkln(Z). This will show you that the entropy is not extensive, as it depends on the number of particles in the system.
I hope this helps you tackle part B of the problem. Good luck with your calculations! Don't hesitate to ask for further clarification if needed.
FAQ: Thermal effusion problem - typical qualifier
1. What is thermal effusion?
Thermal effusion is the process by which heat is transferred between two objects that are in direct contact with each other, but at different temperatures. This transfer of heat occurs due to the movement of particles from the hotter object to the cooler object.
2. What is a typical qualifier in a thermal effusion problem?
A typical qualifier in a thermal effusion problem is a specific condition or parameter that is given in the problem, such as the temperature difference between the two objects, the heat transfer coefficient, or the material properties of the objects.
3. How is thermal effusion calculated?
Thermal effusion is calculated using the formula Q = hAΔT, where Q is the heat transferred, h is the heat transfer coefficient, A is the surface area of contact between the two objects, and ΔT is the temperature difference between the objects.
4. What factors affect thermal effusion?
The factors that affect thermal effusion include the temperature difference between the two objects, the heat transfer coefficient, the material properties of the objects, the surface area of contact between the objects, and the duration of the contact.
5. How is thermal effusion different from thermal conduction?
Thermal effusion is different from thermal conduction in that it only occurs when two objects are in direct contact with each other, while thermal conduction can occur even without direct contact between objects. Additionally, thermal effusion is a surface phenomenon, while thermal conduction occurs throughout the entire volume of the object.
