Homework Help: Thermal expansion coefficent
  1. Mar 31, 2009 #1
    Prove that the volume thermal expansion coefficent of a solid is equal to the sum of its linear expansion coefficients in the three directions: B = Ax + Ay + Az
    2. Relevant equations
    B = (dV/V)/dT
    A = (dL/L)/dT
    3. The attempt at a solution
    My thought was using dV/V = ((dLx*dLy*dLz)/(Lx*Ly*Lz)) but when you use this it is clear that dL^3/L^3 does not equal 3* dL/L
    What am I doing wrong?
    Thanks for the help
  3. Mar 31, 2009 #2
    rl.bhat
    dV= ( Lx +dLx)( Ly +dLy)( Lz +dLz) - Lx*Ly*Lz
    Simplify this and proceed.
  4. Apr 1, 2009 #3
    Can you explain mathematically how you got there?
    Also, the problem statement says at the end (So for an isotropic solid, which expands the same in all directions, B = 3A) if that makes the problem simpler.
  5. Apr 1, 2009 #4
    rl.bhat
    Lx, Ly and Lz are the lengths of the block. When the temperature is raised through 1 degree C, the new lengths will be Lx + Ax, Ly + Ay and Lz+ Az.
    New volume will be (Lx + Ax)( Ly + Ay)( Lz+ Az). Original volume is Lx*Ly*Lz.
    Sp dV = (Lx + Ax)( Ly + Ay)( Lz+ Az) - Lx*Ly*Lz
    Find dV/V. Neglect the terms like Ax*Ay and so on because they are very small quantities.
  6. Apr 1, 2009 #5
    Redbelly98
    Staff Emeritus
    dV = (volume after expansion) - (initial volume)​
    After expansion, the box dimensions have increased by dLx, dLy, and dLz, from their initial lengths Lx, Ly, and Lz.
    EDIT:
    rl responded faster than I. :smile:
