What is the Relationship Between Coefficients for Thermal Expansion?
In summary, the coefficient for volume expansion β is approximately 3 times the coefficient for length expansion α. This can be derived using the equations \DeltaL = \alphaLo\DeltaT and \DeltaV = \betaVo\DeltaT, where β ≈ 3α. However, this is only an approximation and the two methods used to derive this equation may not agree due to the introduction of derivatives and the neglect of higher order terms. This approximation holds true for all shapes as long as the linear expansion equation holds true in all dimensions.
doublefelix92
Hi Physicsforums,
I was trying to derive the formula that the coefficient for volume expansion, β, is 3 times the coefficient for length expansion, [itex]\alpha[/itex].
As a reminder, the formulas are:
[itex]\Delta[/itex]L = [itex]\alpha[/itex]Lo[itex]\Delta[/itex]T
and [itex]\Delta[/itex]V = [itex]\beta[/itex]Vo[itex]\Delta[/itex]T
where, supposedly, [itex]\beta[/itex] = 3[itex]\alpha[/itex].
My proof actually gave me a completely different result. I double-checked it a few times, and I can't find the problem. Does anyone know what's wrong?
here it is: http://imageshack.us/photo/my-images/267/img20111212204020.jpg/
thanks in advance,
doublefelix92
Science news on Phys.org
Get rid of all the terms with higher powers of α. α is usually quite small.
Well, then how come in this proof it works out EXACTLY?
V = L3
dV/dL = 3L2
dL = [itex]\alpha[/itex]LodT
dL/dT = [itex]\alpha[/itex]Lo
dV/dT = (dV/dL)(dL/dT) = 3L2 * [itex]\alpha[/itex]Lo = 3[itex]\alpha[/itex]Vo. Now just turn dV/dT into [itex]\Delta[/itex]V/[itex]\Delta[/itex]T (since dV/dT is constant, you can do that), and you have EXACTLY the equation.
It should come out to the same result, regardless of which proof you use, if you do no approximations.
Edit: I'm guessing the error in this derivation is that L is a function of T, so (L^2)*Lo is not Vo. Checking now if that results in the same equation as the original.
@doublefelix92:
β≈3α. It's only an approximation. That's why your proof went wrong.
If you neglect any higher order terms of α, then you will find β=3α.
Okay. I'm glad that I know it's an approximation. It bothers me, because my textbook (Y&F University Physics) didn't mention that detail WHATSOEVER, and in fact their proof is just plain incorrect; they made an illegal substitution that results in the coefficients being exact multiples.
Anyway - I still have a question. The two ways I'm deriving the equation don't agree. The first method is using V + [itex]\Delta[/itex]V = (LO+[itex]\Delta[/itex]L)3, and plugging in. The second way is to derive the equation starting from V = L^3 and the length expansion equation. I have both of my proofs in the following image.
Why do they not agree?? I re-did them multiple times. What step was illegal?
http://imageshack.us/g/849/img20111213012858.jpg/
Also - ALL of these calculations were just for cubes. Nothing is a perfect cube in real life. How do I know that other shapes follow similar rules?
No reason they should agree. The first involves no approximations at all. In the second method, as soon as you introduce a derivative you've introduced an approximation.
dV = 3L2dL is only true for small changes, yet you treat it as equivalent to ΔV = 3L2ΔL. But that's not quite accurate, as the first method demonstrates. (ΔV really equals (L + ΔL)3 - L3)
As long as you get rid of all higher powers, the two derivations give the same approximate answer.
Nice, that makes perfect sense. Thank you so much. Any idea on the other shapes question? Or is it just true that regardless of the shape, it's always approximately true that [itex]\Delta[/itex]V = 3[itex]\alpha[/itex]VO[itex]\Delta[/itex]T, as long as the equation for linear expansion holds equally in every dimension.
Exactly. (You can think of other shapes as composed of small cubes, if you like.)
What is thermal expansion?
Thermal expansion is the tendency of matter to change in shape, area, and volume in response to a change in temperature.
What causes thermal expansion?
Thermal expansion is caused by an increase in the kinetic energy of particles in a substance, leading to increased movement and separation of the particles.
How does thermal expansion affect materials?
Thermal expansion can cause materials to expand or contract, potentially leading to changes in dimensions and structural integrity. It is important to consider when designing structures and systems.
How is thermal expansion measured?
The coefficient of thermal expansion (CTE) is used to measure the amount of expansion or contraction of a material per degree change in temperature.
Can thermal expansion be controlled?
Thermal expansion can be controlled to some extent by using materials with lower CTE values, or by designing structures with built-in gaps or joints to allow for expansion and contraction. However, it cannot be completely eliminated.
  • Classical Physics
18K
  • Thermodynamics
