Thermal expansion
  • Thread starter Grhymn
Grhymn
You have a square which has a hole inside. When the temperature increases how does it expand?
I know that the hole will expand along with the square, but I don't see why. Can't it expand in both directions: the square getting bigger and the hole smaller?
Answers and Replies
Mapes
Here's one way to look at it: if there are no constraints on the edges of the square, then the material is stress-free. Therefore, you should be able to put a circle of the same material in the empty circle, and the interface will be stress-free. But we know that the circle will expand with increasing temperature. Therefore, the hole must expand exactly the same amount.
If the edges of the square are fixed, however, then the circular hole will shrink. But you didn't specify the edge constraints, so I'm guessing by your answer that you've assumed there are no constraints.
Grhymn
There were no constraints indeed. Thank you for the clarification.
Suggested for: Thermal expansion
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
12K
  • Last Post
