Thermal hydraulics
  1. May 31, 2015 #1
    Hi guys,
    I'm a starter in Nuclear thermal hydraulics course, and I'm having a hard time in solving this problem:
    1. Consider a PWR operating at the thermal power of 1893MW. It contains 193 fuel assemblies, each consisting of 204 UO2 fuel rods 1cm in diameter. Using the equation
    http://file:///C:\Users\Koki\AppData\Local\Temp\msohtmlclip1\01\clip_image002.png [Broken]
    With 200MeV and 180MeV deposited and recoverable energies per fission respectively, and extrapolated radius of 170.2cm and extrapolated height of 365.76cm. Determine the location of the rod with maximum heat generation then calculate the maximum heat generation rate per unit volume in that rod.
    can anyone help??
  3. May 31, 2015 #2
    Astronuc
    Staff Emeritus
    One needs to provide an equation. What axial and radial power shapes does one assume for the core?
  4. May 31, 2015 #3
    This is the given eqn
      File size:
      7.8 KB
      152
  5. May 31, 2015 #4
    Astronuc
    Staff Emeritus
    OK, so where do the maximum values occur for a cosine ( cos (x) ) and Jo ( Jo(r/R) ) Bessel's function?
  6. May 31, 2015 #5
    when r and z = 0
  7. May 31, 2015 #6
    Astronuc
    Staff Emeritus
    Which is where in the core?
  8. May 31, 2015 #7
    The center of the core
  9. May 31, 2015 #8
    Astronuc
    Staff Emeritus
    Correct, or half-way up from the bottom of the core along the central axis.
    One should able to apply the equation with z and r = 0 to find the local power.
    What is the lattice for an assembly with 204 fuel rods? How many guide/thimble tubes? Assume one central tube for instrumentation.
