What is the Temperature of the Rubber Spacer in Thermal Physics Problem?
In summary, the temperature of the two brass plates is 100 C on the open face of the hot brass plate, 0 C on the open face of the cold brass plate, and 100 C at the interface between the hot brass plate and the rubber.
butters120
Two brass plates, each 0.5 cm thick, have a rubber spacer sheet between them, which is 0.1 cm thick. The outer side of one brass plate is kept at 0 oC, while the outer side of the other is at 100 oC. Find the temperature of the two sides of rubber spacer if the thermal conductivity of brass is approximately 500 times higher than that of rubber.
I have Q/t=KA[dT/dx] and Q/t=A(Th-Tc)/sum of (Li/Ki) where Ki=thermal conductivity of each material and Li= thickness of material.
I have tried setting the Q/t=A(Th-Tc)/sum of (Li/Ki) equal to each other for each brass sheet, like i had split the spacer sheet up, but i don't think this is right. other than that i do not know where to go from the equation. Please help :(
Yes, good.
What can you say about Q/t/A, for each of the 3 pieces?
p.s. welcome to PF :smile:
hmm, for steady state transfer would they be equal? I am really not sure about this :( would i set k[Dt/dx]=k[dT/dx] for the brass and the rubber? with K=500 for brass and K=1 for rubber? and maybe Th = 100 in one case and Tc=0 in the other and get T ? i don't know i am el stupide
Yes, exactly.
Close, but there are 3 slabs, so think of it this way:
k1 [Dt/dx] = k2 [dT/dx] = k1 [dT/dx]​
Then figure out how Th=100C and Tc=0C go into this.
There will be two unknown temperatures to solve for.
what would be the 3rd? would i set th=100 for 1 brass slab, Tc=0 for the other slab; i am unsure what is happening for the 3rd slab :S
There are two brass slabs, plus a rubber slab.
Perhaps it will be easier to proceed if you go ahead and replace the dT/dx terms with the appropriate temperatures and slab thicknesses.
I have: 500(100-Tc)/0.5=500(Th-0)/0.5=(Th-Tc)/0.1
but i either get 50 or 0 and i somehow don't think this is correct :(
You're equations are almost correct.
Where do the temperatures Th and Tc occur? It seems you might have mixed them up, so I'd like to know how you are defining them.
p.s.
Don't worry, we are getting close to solving this.
erm i have said Th=100 at one of the brass plate to the rubber, Th-Tc is the temperature difference across the rubber, and used Tc=0 assuming that the heat from the rubber is being transferred to the brass; i think this is the part that is wrong. ahh its infuriating me now :(
Okay, let's try this:
T=100 C on the open face of the hot brass plate.
T=T1 at the interface between the hot brass plate and the rubber.
T=T2 at the interface between the cold brass plate and the rubber.
T=0 C on the open face of the cold brass plate.
ahhhh
i give up i can't do it :(
1. What is thermal conductivity?
Thermal conductivity is a measure of a material's ability to conduct heat. It is the rate at which heat energy can pass through a material, typically measured in watts per meter-kelvin (W/m•K).
2. How is thermal conductivity calculated?
Thermal conductivity is calculated by dividing the amount of heat energy transferred through a material by the product of the cross-sectional area, the temperature difference, and the time it takes for the heat transfer to occur. This is known as Fourier's Law.
3. What factors affect thermal conductivity?
Thermal conductivity is affected by several factors, including the type of material, its density, temperature, and moisture content. Generally, materials with high thermal conductivity have a higher density and lower moisture content.
4. How does thermal conductivity impact heat transfer?
Thermal conductivity plays a significant role in heat transfer, as it determines how quickly heat can pass through a material. Materials with high thermal conductivity are better at conducting heat and therefore have a higher rate of heat transfer.
5. Can thermal conductivity be changed?
Yes, thermal conductivity can be changed by altering the properties of the material. For example, adding insulating materials can decrease thermal conductivity, while adding conductive materials can increase it. Additionally, temperature and moisture levels can also affect thermal conductivity.
  • Mechanical Engineering
12K
