Thermal Equilibrium of Lens and Disk in Solar Projection
In summary, the conversation discusses the use of a lens with a small radius and focal length to project the image of the sun onto a disk. The lens also magnifies the image to completely fill the disk. The temperature of the disk can be computed by comparing the flux in and out of the disk, resulting in a formula of $T_{disk}=T\sqrt{\frac{R}{d}}$, where d is the distance from the sun to the disk and R is the radius of the sun. The conversation also mentions the scenario of not using a lens and how the temperature would be affected.
nicu15
Lens & Disk
The image of the sun is projected on the disk using a lens of radius r<<d and focal length f<<d (d is the distance between the sun and the disk.. The magnification of the lens is M`f/d, so that the image completely fills the disk R`=MR. When the disk reaches thermal equilibrium, what is its temperature?
I don't really know where to start, so a hint would help a lot.
Thanks
How would you do the problem if there was no lens?
I've already done that part.
Computed the flux in and compared it with the flux out of the disk. got a temperature of $T_{disk}=T\sqrt{\frac{R}{d}}$ where d is the distance from the sun to the disk and R is the radius of the sun.
... good.
So what does the lens do in terms of the solar flux that gets to the disk?
for your question. The thermal equilibrium of the lens and disk in solar projection is an interesting concept to explore. In order to determine the temperature of the disk in thermal equilibrium, we need to consider the energy balance between the incoming solar radiation and the heat emitted by the disk. The lens and disk system acts as a sort of "solar collector", focusing the sun's energy onto the disk and converting it into heat.
To find the temperature of the disk, we can use the Stefan-Boltzmann Law, which states that the energy emitted by a blackbody is proportional to its temperature to the fourth power. In this case, we can assume that the disk is a blackbody, as it absorbs all incoming radiation.
We also need to consider the energy absorbed by the lens, which will contribute to the temperature of the system. This can be calculated using the lens' transmittance and the amount of solar radiation it receives.
In order to reach thermal equilibrium, the energy absorbed by the disk and lens must be equal to the energy emitted by the disk. This will result in a balance of energy and a stable temperature.
Therefore, to find the temperature of the disk, we can use the following equation:
Energy absorbed by disk + Energy absorbed by lens = Energy emitted by disk
We can then solve for the temperature of the disk using the Stefan-Boltzmann Law and the known values of the disk's radius, focal length, and magnification.
I hope this helps to guide you in finding the temperature of the disk in thermal equilibrium. It is a complex system with many factors to consider, but with the proper calculations and understanding of the laws of thermodynamics, we can determine an accurate result. Best of luck in your research!
What is thermal physics?
Thermal physics is a branch of physics that studies the behavior of matter at the microscopic level in relation to temperature and heat. It focuses on understanding how energy is transferred between different forms and how it affects the properties of matter.
What is the difference between temperature and heat?
Temperature is a measure of the average kinetic energy of the particles in a substance, while heat is the total amount of thermal energy transferred between two objects. Temperature is an intensive property, meaning it does not depend on the amount of substance, while heat is an extensive property that depends on the mass and specific heat capacity of the substance.
What is the relationship between work and heat in thermal physics?
The first law of thermodynamics states that the change in internal energy of a system is equal to the amount of heat added to the system minus the work done by the system. This means that work and heat are interchangeable forms of energy and can be converted from one to the other.
What is thermal equilibrium?
Thermal equilibrium is a state where two objects in contact with each other have the same temperature and there is no net flow of heat between them. In other words, the rate of heat transfer from one object to another is equal to the rate of heat transfer in the opposite direction, resulting in a stable temperature for both objects.
What is the significance of the Boltzmann constant in thermal physics?
The Boltzmann constant, denoted by k, relates the average kinetic energy of particles in a gas to the temperature of the gas. It is a fundamental constant used in many equations and laws in thermal physics, such as the ideal gas law and the Maxwell-Boltzmann distribution. It also helps to connect the macroscopic properties of a substance, such as temperature and pressure, to the microscopic behavior of its particles.
  • Optics
