Is stored energy present in a bar that expands freely due to thermal induction?
In summary, thermal energy is associated with the vibration of the molecules in a solid and is not related to the work done. There is zero work done in the process of expansion and therefore the thermal energy is not accounted for.
Hassan2
426
When a bar is heated evenly, and it expands freely, they say it has zero induced stress. How about the stored energy? Isn't some energy stored in the process of expansion? Can this energy be calculated the same way the elastic energy is calculated? If so, why we state that it has zero stress?
Thanks.
Science news on Phys.org
Like you said, the bar is allowed to expand freely. However, if it isn't (e.g. stuck between two pillars) the bar cannot expand at all. There's a force acting on the bar, and that force causes thermal stress.
That's a good question and here is what I hope is a good answer.
When you heat something that is free to expand you put in themal energy not work.
This energy input is not calculated by the same equations as elastic strain energy.
Think about this, there is zero resisting force so any work that equals the force times displacement (expansion) equals zero.
So where does the energy go?
It raises the temperature of the body.
You calculate this energy input as the specific heat times the temperature change.
To further understand this at a molecular level.
Start with the solid lattice at equilibrium. That means the intermolecular forces are balanced.
The lattice energy is the potential energy held in all these balance internal forces.
Elastic strain energy is extra potential energy held in the matrix of the material as a result of applying an external force and straining it. It represents the non equilibrium increase in average separation between the molecules. That is in a strained solid there exists a restoring force due to the external applied force, because the matrix is no longer in equilibrium without them.
Thermal energy is the kinetic energy of the molecules. In the case of solids it is vibrational energy - they vibrate further and faster as you heat them.
These vibrations are all about the equilibrium position of the molecules.
When the solid expands due to thermal vibrations the lattice or matrix is always still in equilibrium. There are no 'restoring forces'. This equilibrium without restoring forces is maintained even though the molecules are now further apart.
You should not confuse the elastic 'restoring forces' with the restoring forces associated with the simple harmonic motion of vibration. They are separate forces although they stem from the same cause viz the intermolecular forces.
If you think about liquids and gasses, the separation between kinetic and potential energy is even more distinct.
The elastic potential energy is measured by fluid pressure and again the heat energy is measured by the specific heat times temperature change.
1. What is thermally induced stress?
Thermally induced stress is a type of mechanical stress that occurs when a material or structure is subjected to changes in temperature. It is caused by the expansion or contraction of a material due to temperature changes, which can lead to internal forces and strains within the material.
2. How does thermally induced stress affect materials?
Thermally induced stress can cause materials to deform, crack, or fail if the stress becomes too great. It can also lead to changes in the material's physical properties, such as strength and stiffness. In extreme cases, thermally induced stress can cause catastrophic failures in structures and equipment.
3. What factors influence thermally induced stress?
The amount of thermally induced stress depends on several factors, including the material's coefficient of thermal expansion, the temperature difference between the material's initial and final states, and the geometry and constraints of the material. Other factors, such as the rate of temperature change and the thermal conductivity of the material, can also play a role.
4. How can thermally induced stress be managed or controlled?
Thermally induced stress can be managed through careful design and material selection. By choosing materials with low coefficients of thermal expansion, using appropriate joint designs, and controlling the temperature gradient within a structure, the effects of thermally induced stress can be minimized. Other methods, such as thermal insulation and coatings, can also help control thermally induced stress.
5. What are some common applications of thermally induced stress in science and engineering?
Thermally induced stress is a common phenomenon in many scientific and engineering applications. It is a major consideration in the design of structures, such as bridges and buildings, where temperature changes can cause significant stresses. It is also important in the manufacturing of products, such as electronics and ceramics, where thermal stress can affect the reliability and performance of the materials. Additionally, thermally induced stress is a crucial factor in many industrial processes, such as welding and heat treatment, that involve heating and cooling of materials.
  • Thermodynamics
  • Mechanical Engineering
  • Thermodynamics
10K
12K
  • Thermodynamics
