Homework Help: Thermo Equilibrium question
  1. Sep 23, 2008 #1
    A cylindrical container 80cm long is in two compartments seperated by piston, clamped at 30cm from left end. The left compartment is filled with 1 mole of He at 5atm. Right compartment is filled with argon at 1atm. Both gases may be considered ideal. Cylinder is submerged in 1L of H20 @ 25°C. When piston is unclamped, a new equilibrium is reached with piston in new position. The entire system is thermally and mechanically isolated and you may ignore the heat capacities of the cylinder and piston.
    What is the increase in Temp of the water at new equilibrium? How far from left of the cylinder will the piston come to rest? What is increase in total entropy of the system?
    2. Relevant equations
    What I think I can use, are entropic equations regarding the variables, E, T, P, V:
    [tex]\frac{dS}{dE}[/tex]=[tex]\frac{1}{T}[/tex]
    [tex]\frac{\partial{dS}}{\partial{dV}}[/tex]=[tex]\frac{P}{T}[/tex]
    Since the equilibrium must be reached when entropy is max, then dS[tex]_{1}[/tex]+dS[tex]_{2}[/tex]=0
    3. The attempt at a solution
    Ok, so I'm guessing that we can relate the pressures and temperatures with
    [tex]\frac{dS_{1}}{dV_{1}}[/tex]=[tex]\frac{P_{1}}{T}[/tex]
    [tex]\frac{dS_{2}}{dV_{2}}[/tex]=[tex]\frac{P_{2}}{T}[/tex]
    meaning, that the temps should be equal after equilibrium.
    The displacement of the piston would be a ratio of the two volumes at the new equilibrium.
Draft saved Draft deleted
Loading...
