Thermo Question
  • Thread starter suspenc3
suspenc3
402
I have a question involving putting an ice cube in a thermos of coffee. I used [tex]c_{ice}m_{ice}(T_f-T_i) + c_{coffee}m_{coffee}(T_f-T_i)=0[/tex]. Is this right? If so wouldn't the temperatures of the ice remain constant until it is all gone?It says that the ice is at 0'C.
Answers and Replies
Noein
32
The approach is correct, but there is a term that is missing in your equation: the heat needed to completely melt the ice cube.
suspenc3
402
How do I find this..If say the ice was at -10'C then i could do this by using Tf=0..But since it is already at its melting point, I am kinda confused
suspenc3
402
waiitt...Q=Lm?
turdferguson
312
Heat Lost = Heat Gained, the heat lost by the coffee melts the ice first (mL) and then raises it to a higher temperature (mcdeltaT)
suspenc3
402
So my equation is going to become [tex]L_Fm + c_{ice}m_{ice}(T_f-T_i) + c_{coffee}m_{coffee}(T_f-T_i)=0[/tex]? and then will [tex]c_{ice}m_{ice}(T_f-T_i)[/tex] become zero since the ice isn't going to change Temp until it has changed phases
turdferguson
312
It depends on the numbers. If the final temperature is above 0 degrees, then there was enough heat to both melt the ice and raise the temperature of the new water above 0 degrees
Something else to point out is that the problem wouldn't be simpler if the ice started out at -10 degrees. You would need to determine (in this order) the heat used to raise the temperature to 0, the heat to melt the ice, and the heat to raise the water temperature above 0
Suggested for: Thermo Question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
