Thermo Tables for r-144a
  1. Nov 1, 2007 #1
    I have some equipment that uses an older refrigerant that I am having a hard time finding any uselful data on. It is r-144a, and if anyone has any idea as to where I could find a thermo properties table on this stuff, let me know. I've been looking everywhere, hundreds of websites, countless books, and nothing. Any info would be greatly appreciated.
  3. Nov 1, 2007 #2
    stewartcs
    Never seen anything on R-144a...R-143a I have, but not 144a.
  4. Nov 2, 2007 #3
    FredGarvin
    How about R-134a? I have not heard of either of those.
  5. Nov 2, 2007 #4
    stewartcs
    I have the properties for R-143a and R-134a if you need them.
  6. Nov 2, 2007 #5
    FredGarvin
    There's a 143a? Huh. Ya learn something new every day.
  7. Nov 2, 2007 #6
    stewartcs
    Yep. I have a NIST database full of useful information on fluids. NIST used to offer the data on their website, but they sell it now in a nice and tidy little program.
  8. Nov 4, 2007 #7
    I didn't double check when I posted, I actually need thermo properties on r-141b. Not sure if r-144a even exists. If the equipment used r-134a, this would be a lot easier, you can find those tables everywhere. Still, if anyone can tell me where to look for these tables, I would appreciate it.
  9. Nov 4, 2007 #8
    stewartcs
    R141b - CCl2FCH3 - 1,1-dichloro-1-fluoroethane
    CAS#: 1717-00-6
    Molar mass: 116.95 lbm/lbmol
    Triple point temperature: -154.25 °F
    Normal boiling point temperature: 89.69 °F
    Critical point temperature: 399.83 °F
    Critical point pressure: 610.9 psia
    Critical point density: 28.627 lbm/ft³
    Gas phase dipole at NBP: 2.014 debye
    Acentric factor: 0.2195
    Equation of State
    Equation type: Helmholtz energy
    Limits: -154.25 °F to 440.33 °F, 58015.0 psia, 91.7 lbm/ft³
    Lemmon, E.W. and Span, R., "Short Fundamental Equations of State for 20 Industrial Fluids," J. Chem. Eng. Data, 51:785-850, 2006.
    The equation has uncertainties of 0.2% in density between 180 and 400 K at pressures to 100 MPa, and 0.5% in density at higher pressures. The uncertainty in density may be higher as temperatures approach 400 K. Vapor pressures are represented with an uncertainty of 0.2% from 270 to 400 K. The uncertainty in speed of sound is 0.01% in the vapor phase and 0.5% in the liquid phase. Heat capacity data are not available to verify the equation of state, however, the uncertainties are estimated to be within 5 %.
    Viscosity and Thermal Conductivity
    Huber, M.L., Laesecke, A., and Perkins, R.A., "Model for the Viscosity and Thermal Conductivity of Refrigerants, Including a New Correlation for the Viscosity of R134a", Industrial and Engineering Chemistry Research, 42:3163-3178, 2003.
    SOURCE: NIST Database
    Hope this helps...
    Chris
  10. Nov 7, 2007 #9
    Mech_Engineer
    RefProp is a very cool program. making your own thermodynamic tables is so very nice.
    That being said, NIST does have a very large amount of fluid properties available online for free (including R-141b):
    http://webbook.nist.gov/chemistry/fluid/
  11. Nov 7, 2007 #10
    stewartcs
    I knew they used to have that web database, I had lost the link though since I had the program.
    Good to know they still offer it for free! RefProp has a lot more functionality than the web database though.
  12. Feb 20, 2010 #11
    Hi ( R_Schuette )
    I was searching for anything to re-charge my R-12 So I found Something Maybe It Will Be More Useful For Your Issue And
    otherwise it helps me to re-charge my R-12
    Following Link
    http://www.rizkbrothers.com/Arabic/products.php?tn=cHJvX3Byb2R1Y3Rz&for=MzE%3D&main=0&sub=0&pro=31&lan=Ar [Broken]
  13. Mar 4, 2010 #12
Similar Discussions: Thermo Tables for r-144a
  1. Thermo Problem (Replies: 0)
Loading...
