Does the Third Law of Thermodynamics Apply in Quantum and Cosmic Contexts?
In summary, Thermodynamic Cosmic Problem asserts that the universe is finite in length, and that the vacuum fluctuations prove this. Furthermore, classical cosmology leads to the same observable results as the Einstein-de-Sitter-Model. However, GR theory suggests that the space itself is expanding.
pranav_bhrdwj
Thermodynamic Cosmic Problem !
Ill start with the third law of thermodynamics which denies the existence of zero kelvin (as stated by my lecturer). Also i found out that the temperature of vacuum is 3k due to the radiations left over from the Big Bang. However the space(or the absolute vacuum) which exists beyond the expanding universe must be at zero Kelvin as it has no access to the radiations which would be expanding at the speed of light. Doesn't this fact violate the 3rd law of thermodynamics ?
Thanks in advance !
Science news on Phys.org
"Beyond the expanding universe"? There is no such thing.
It's not an expansion in space. It's an expansion of space.
That's not true. the third law states that zero kelvin is unreachable. Quantum mechanics confirmed this by investigations of the Casimir effect: there's no obligation that you read this obviously, unless you find it interesting:
http://en.wikipedia.org/wiki/Casimir_effect
Essentially the ground state of any Quantum electromagnetic field is non-zero.
woooaaa! please let's keep this a science forum. Nonetheless I do enjoy a bit of philosophic banter every so often. But then how do you define the universe if it has well defined edges, and at the same time, is just the emptiness within which everything else exists in. It is a rather circular argument. The true scientist would tell you, that the universe expanded with matter from the Bigbang (copyrighted by some american millionaire?) and at the same rate, and so you cannot define universe if you don't have matter there essentially. I would not be so happy to go with that view. I would tell you that any speculation about the apparent size, or direction of the expansion of the universe cannot be absolute. In essence we may be at a point in the universe that we might have been at billions of years before and over and over again. Unless you're investigating it from the outside, there's no well defined position in the universe, but there are well defined position-time vectors.
In the model, which won the noble prize for describing the vacuum fluctuations, the assumption is that the E.M. field from the bigbang is bounded by the size of the universe, and that is the reason why there's a non-zero solution at every point inside. In fact if the radiation wasn't there, that would be evidence that the universe may not be finite at all...
There is a difference between existing and reachable.
@Ardie : I'm really thankful to you for such an elaborate explanation. And i agree, 'existing and reachable' (in relation to 0k) are 2 very different things. But since i have yet to read quantum mechanics in my upcoming semesters i apologize for my inability to appreciate the 'Casimir effect'.
However what i could make out from your second argument was that my understanding of the universe and space (which i referred to as the absolute vacuum :P) as seperable is at fault. I understand the space as something in which universe is expanding (initiated by the big bang). I would be grateful if you correct me !
This is classical cosmology. It surprisingly leads to the same observable results as the Einstein-de-Sitter-Model. However as classical mechanics is falsified the corresponding cosmological models are invalid too. In GR the space itself is expanding.
What should i then think of the universe and space ?
p.s : i am yet to complete my bachelors in physics so i'd be pleased if u could explain it to me keeping that into consideration !
I think it is important to know what we know exactly as we do the calculations, rather than simplify them just so that you understand in classical terms, because there is really no alternative. If classical mechanics really explained everything, then there wouldn't be so much success attached to quantum mechanics.
The very existence of the vacuum fluctuations (3k everywhere in space) is direct evidence that the universe is finite in length, and that is so because of exactly what you said; otherwise the photons would have escaped by now. Let's not speculate as to where, but if you try and solve the Q.M. equations for light in an infinite boundary (no boundaries), you must get 0 intensity everywhere, but you do not.
to ardie: I don't think the Casimir effect says anything about 0 temperature being unreachable. I think you are confusing temperature with energy. Zero point energy has no bearing on the temperature. Also, I don't follow your argument for why the universe is finite.
pranav: The big bang encompassed the entire universe, so there is no "outside the reaches of the big bang".
Thanks in advance !
What your lecturer actually meant that “it is impossible for any procedure to bring a system with a positive absolute temperature to absolute zero of temperature in a finite number of steps.” In order for the third law to be useful, the absolute temperature of the system has to be more than zero.
If there was a region outside the visible universe which had a temperature of absolute zero, then it didn’t need any steps to bring it down to zero. It was already at absolute zero, and will remain there until energy, momentum and entropy reach it.
I doubt there is a region of space which is completely empty of energy or matter. However, if there is then it is already at absolute zero and has always been at absolute zero. The third law does not say, “There can’t be a region of space that was always at absolute zero.”
If there is a closed system at a positive absolute temperature, then one can always bring the temperature down using a single step process. The temperature can asymptotically approach zero in the limit of infinite time. One can divide the positive temperature by 2, 4, 6, 8, etc. One can get as close to absolute zero as one wants by more steps. This will take time. However, one will never get to absolute zero in finite time.
There is more than one way to express the Third Law of Thermodynamics. This link has an article presenting some of the equivalent ways of stating the Third Law.
http://en.wikipedia.org/wiki/Third_law_of_thermodynamics
“The entropy of a perfect crystal at absolute zero is exactly equal to zero…
The entropy of a system approaches a constant value as the temperature approaches zero…
Physically, the law implies that it is impossible for any procedure to bring a system to the absolute zero of temperature in a finite number of steps…”
On a gross engineering level, the third law is really saying, “The specific heat of all materials gets very, very big at temperatures close to absolute zero.”
I think the second expression is probably the one that is most useful in application. Laboratory measurements can be used to determine the functional dependence of absolute entropy on absolute temperature in a closed system. One can falsify the Third Law as follows.
One can not know what is happening beyond the edge of the visible universe. The practical question is really how the Third Law relates to laboratory measurements. Therefore, the real question that you may be asking is whether the Third Law can be falsified on a laboratory scale. The third law has never been falsified in the laboratory. However, I propose the following method for falsifying the third law.
Determine the entropy of a material as a function of temperature by experimental measurement. Of course, there will be uncertainties in the measurements. However, one can decide on engineering tolerances based on these uncertainties. If there is a relative minimum in entropy at zero absolute temperature, within whatever tolerances one decides on, then the results are consistent with the Third Law. If the entropy doesn’t reach a relative minimum within the tolerances of the theory, then the Third Law is falsified.
For me, the most interesting part would be the engineering tolerances. This is a matter of statistical analysis, not fundamental physics.
i may have confused cosmic background radiations with vacuum fluctuations. either way even if you manage to get rid of the cosmic radiations, you cannot get rid of the nonzero vacuum fluctuations ground state energy. btw temperature is another measure of the internal energy.
The nonzero background fluctuations are not part of the energy that contributes to absolute temperature. The energy density of the quantum fluctuations is always infinite, even at absolute zero. The 3 Degree cosmic background radiation is not a vacuum quantum fluctuation per se. In particle terms, the vacuum fluctuations correspond to virtual photons and the 3 degree radiation corresponds to real photons. In wave terms, the vacuum fluctuations have a Lorentz invariant spectrum and the 3 degree radiation has a Planck thermal spectrum.
The Third Law would apply to a region of space that initially has the 3 degree radiation. One could refrigerate this portion of space to within any fraction of a degree Kelvin using a finite number of states. However, you could never refrigerate this portion of space to 0 degrees Kelvin in a finite number of steps. The refrigeration would not eliminate the vacuum fluctuations, no matter how many steps it involves.
Thanks a lot Darwin123 (for this part) because i really got where i went wrong. In fact all my misconceptions regarding the 3rd law have been cleared. However the statement
is still unclear.
Also I'm curious to understand your way of falsifying the third law. I would be grateful if you explain it to me in a bit more simpler terms (I'm yet to complete my bachelors in physics) !
Thanks !
@Ardie : I request you to allow me some time before i get back to you as I'm reading stuff on the understanding of space :) Thanks
Thanks !
First, understand that I was speculating. To understand what I was saying, let's reduce that Third Law of Thermodynamics to differential equations and inequalities. Instead of mucking around with visualization, let us try to express the Third Law mathematically. Once we have a mathematically formal way to express the Third Law, then we can think about experimental ways to falsify or validate it.
I don't have any references that precisely express the Laws of Thermodynamics the way I showed you. However, there are plenty of textbook examples which use equations like them.
One way to express the Third Law is by stating that the entropy of a closed system is at a minimum at zero absolute temperature. Let us write some differential equations equivalent to that.
The entropy of a closed system near equilibrium is a function of state variables including absolute temperature. That is,
1) S=S(T,P,V,{u_i})
where for the closed system T is absolute temperature, P is pressure, V is volume, u_i is the i'th state variable and {u_i} is a complete set of such state variables. The entropy S is a continuous function of T. Basically, equation 1 is equivalent to saying entropy is a perfect differential in terms of reversible processes. However, I promised not to go deeply into visualizations.
The second law states that the total entropy of a system must never decrease, and that the entropy can never spontaneously flow from a high temperature system to a low temperature system. The second law is basically equivalent to the statement that if,
2) T>0,
then,
3) ∂S(T,P,V,{u_i})/∂T>0.
Equations 2 and 3 are mathematically formal expressions for the second law. The more visual expressions for the third law can be derived from equations 2 and 3, provided we carefully define what a system variable is. However, I think you can roughly see how 2 and 3 is approximately equivalent to the other expressions of the second law.
From introductory calculus, one knows how to find the minimum of a function. If S is at a relative minimum at T=0, then,
4) ∂S(T,P,V,{u_i})/∂T=0,
and,
5)∂^2 S(T,P,V,{u_i})/∂T^2 > 0.
The last two equations are mathematical expressions for the third law. One can see that finding absolute zero is basically the same as finding the minimum of the function, S. Because of the second law (equation 3), one can see that there is only one relative minimum in S. There is only one zero absolute temperature.
If you look at number 4, you see that one needs an infinitely large change in entropy to produce a finite change in temperature at T=0. This is basically the third law.
Of course, these mathematical equations have several physical hypotheses hidden in them. I haven't told you how to measure S, for instance. However, I hope that you get my point. The Four Laws of Thermodynamics (0, 1,2, 3, 4) are quantitative theories. They are used to define differential equations with quantitative solutions.
To falsify the Third Law, you have to show that in the limit of T=0,
6) ∂S(T,P,V,{u_i})/∂T≠0.
Experimentally, one would determine S as a function of T for any fixed set of state variables. If one can determine that at T=0, equation 6 is probably true, then one has proven that the Third Law is probably false.
I can rewrite these equations several says. However, proving the Third Law of Thermodynamics is true is basically proving that equations 4 and 5 are true. Experimentalists have to deal with uncertainties and tolerances, which is why I tried to explain the procedure in the way I did. A good experimenter never absolutely proves something, he proves something to within a certain tolerance. But without going through grungy statistical details, the experimenter would try to prove equations 4 and 5 as T approaches 0. One is measuring the slope of the S versus T curve. One extrapolates to T=0.
On Darwin's approach I am going to return this??
First of all, the statistical way of defining the entropy (entropy as a quantity is not measurable) is:
S= k lnW
where k is Boltzman's constant
and W is the number of microStates that build up your given MacroState.
This can be proved in several ways... by having a general S function: S=k Σ[pr lnpr] where pr is the probability of the microstate r, and trying to minimize it for fixed quantities of energy or number of bodies (Boltzman's formula above is a deduction of this approach, by saying you have a fixed total energy for your system)
BUT
at absolute zero (T=0K) your system falls to its ground state. So W=1 if there is no degeneration. Given that S=0 for T=0.
by the way something interesting I read (all my idea came by Landau & Lifgarbagez, paragraph 23, p68-70). From the same quote I read, that entropy goes to zero, for T going to 0, is true only when other quantities remain fixed (such as vollume and pressure). If the temperature (it says) of our system decreases to zero, while its density also decreases without limit, then the entropy need not tend to zero... this sounds quite interesting for even our universe...
S= k lnW
BUT
Who needs statistics?
Thermodynamics is most useful in its phenomenological form, which doesn't need statistics. In most chemistry problems, the statistical expression for entropy is not useable. One doesn't know how to calculate the degrees of freedom in any realistically complex system.
The change in entropy can be determined by calorimetric experiment without knowing a single thing about the atomic structure of what one is looking at. The statistical mechanics can actually be confusing if all you want to know is the available work.
Statistics has its place. It is really important in certain types of problems. However, pure thermodynamics is most useful as a short cut through statistical mechanics. It is a way of avoiding the unimportant details to get right at what is most important to the problem. So I think the right way to learn thermodynamics is starting with the macroscopic system.
I prefer a more visual way of learning thermodynamics that defers probability and statistics. Entropy is an indestructible fluid that permeates other matter. Temperature is the pressure of this fluid. This should be the start of a thermodynamics course.
This was suggested in the following article:
Hans U. Fuchs, "Entropy in the teaching of thermodynamics," American Journal of Physics 55(3) 215-219 (March 1987).
The abstract reads:
"An elementary physics course in thermodynamics is presented. It uses entropy and temperature as fundamental, undefined objects."
So that is how I like to explain thermodynamics. Start with entropy and temperature as fundamental objects.
S= k lnW
Entropy can be determined from calorimetric measurements. If ones measures the specific heat of a material as a function of temperature, then one can determine the entropy. Hence, entropy can be effectively "measured".
The number of microstates can't be measured. The number of microstates can't even be numerically determined in detailed theory. The number of microstates can be determined once the total entropy is determined.
How many chemists do you think do a precise molecular dynamics simulation to find the enthalpy of a chemical reaction? How many chemists do you think use a precise molecular dynamics simulation to find the change in entropy of a chemical reaction?
There may be a few, these days. I conjecture that a lot more use calorimetry to determine both the change in enthalpy and the change of entropy in chemical reactions.
Statistical physics ain't that bad, in the way they give answer to many problems. It reconstructs the already known phenomenological data, or the "classical thermodynamics" but it can be used in quantum mechanics way better.
For example if you try to determine the entropy of an ideal gas, you will eventually end up in an expression for S that doesn't equal to 0 for T->0. That is a problem of classical thermodynamics. It can be overpassed in the quantum level, and quantum thermodynamics have both statistics and probability instinctively in them. Nerst's theorem (or the 3rd law) is a deduction of quantum statistics and cannot be purely taken by classical approaches.
In some cases the number of the microstates can be determined thanks to the problem (Like Ising model). In fact I can't think of Quantum Statistics in the Classical Thermodynamics Approach. They diverge in results!
when you say that a physical quantity is not measurable, it means you can't measure it straightforward through an experiment (There is no machine which you can put in your system and measure its entropy). The heat and temperature are measurable, and due to their measuring, you can then CALCULATE the entropy.
As for the chemists... they are chemists!
I mean
they don't need to consider that low temperatures in their experiments.
Classical approaches work for their region good enough, and without GREAT divergences... If i want to experiment with gravity on the Earth with normal measuring machines, i will use Newton, not General Relativity...however GR is way closer to reality.
However, when solid state physicists work with crystals, they take in account the statistical physics, rather than thinking in the classical way. Even more for elementary particles (like BoseEinstein and FermiDirac distributions, which come by statistical physics only, and thanks to them we have semiconductors and so on) or the entropy of a BlackHole I guess and so on...
I must say I am intrigued. Those are beautiful descriptions, and they are often sparse in a Thermodynamics book.
Either way I believe solving this problem cannot be by means of Thermodynamics alone, as the temperature of the cosmic background radiation is not due to a fluid, or any classical form of matter. The approach must refer to the quantum nature of the waves that propagate across the universe in some way or form.
A lot of this can be addressed by Thermodynamics alone, since thermodynamics isn't completely classical. The equation of state of a system can incorporate quantum effects without messing up the Four Laws of Thermodynamics. As you pointed out, the Third Law of Thermodynamics incorporates some quantum effects. Thus, by using the Third Law of thermodynamics you automatically resolve most of the discrepancies between thermodynamics and classical physics.
The Cosmic Background Radiation is electromagnetic radiation. Thus, it is made up of photons, which are bosons. Thus, they do follow a Bose-Einstein distribution for thermal bosons. Equations of state can be derived using the Bose-Einstein distribution, which don't affect the Laws of Thermodynamics in any way.
I was not saying that statistical mechanics was worthless in cosmology. I was addressing the OP's question. He was inquiring about a perceived contradiction between cosmology and the third law of thermodynamics. I was pointing out that his logic was incorrect.
What the OP was describing was a free expansion of a photon gas. It doesn't matter that the photons in his scenario were from the Cosmic Background Radiation and the vacuum was a previously undiscovered region of outer space. What he called a vacuum was really filled with bosons. What he called the area "outside the universe" was a true vacuum. I don't know if the entire universe can be described that way. Probably not! However, we can't be absolutely sure that this picture is completely wrong. It doesn't really matter with regards to the Third Law.
What we do know, based on experiments done on earth, that the Four Laws of Thermodynamics are completely consistent with the free expansion of a gas into a vacuum. The gas in this case consists of bosons, but it doesn't matter. The physical properties of photons would be incorporated in the equation of state.
The OP's problem was basically standard calorimetry. Someone else brought up the statistical mechanics of entropy. However, the statistical mechanics adds complexity to the problem without clarifying anything.
The answer that I should of given was very simple. The OP was describing the free expansion of a photon gas into a vacuum. The Four Laws of Thermodynamics are completely consistent with free expansion of any gas into a vacuum. If there is a perceived contradiction with any of the Four Laws, then there probably is a problem with the way the Four Laws are stated.
In the OP's case, the problem was in the way he stated the Third Law and the problem. In thermodynamic terms, the visible universe wasn't a true vacuum. It was a container of photon gas. The region outside the universe wasn't really outside the universe. It was the region outside the container. Initially, the region outside the container was a true vacuum. The gas expanded into the vacuum. Free expansion has been studied for years without reference to statistical mechanics.
I just realized. Your problem is very general. You were merely describing the free expansion of a photon gas from a container into a vacuum.
I wrote to someone else in this thread. However, I summarize.
The free expansion of a gas into a vacuum does not contradict any of the Four Laws of Thermodynamics. The Cosmic Background Radiation is just an exotic gas. It has a nonstandard equation of state which can be derived by the statistics.
Your proposed scenario is not truly a "Thermodynamic Cosmic Problem". It is a little more general than that. It is a "Thermodynamic Free Expansion Problem" with a photon gas.
Your cosmic background radiation (CBR) is a fluid. The cosmic background radiation is a photon gas, which is a type of fluid. The CBR may not be classical form of matter, but it is a fluid which has been studied for a long time.
Here are some links showing how the free expansion of black body radiation is analyzed using thermodynamics. Note that the Cosmic Background Radiation is black body radiation at a temperature of 3 degree Kelvin. Therefore, it is a “classical” form of energy if not matter.
I included a whole lot of references which address the expansion of a photon gas into a true vacuum. These references include analyses from a “pure thermodynamics” viewpoint, with little or no statistical mechanics.
The following link has a whole chapter on the third law of thermodynamics.
http://www.rpi.edu/dept/phys/courses/PHYS4420/BlackBodyThermo.pdf
“The Thermodynamics of Black Body Radiation”
…Third Law of Thermodynamics
The weak form says that the change in entropy for an isothermal, reversible process approaches zero as temperature approaches zero, whereas the strong form says that the entropy is zero at T=0. Notice that the strong form contains the weak form as a special case….
If equation (3) is correct for blackbody radiation, then … corresponding to the strong form.”
Your model universe may contain both photons and neutrinos. The following reference discusses the thermodynamics of such a system.
http://ajp.aapt.org/resource/1/ajpias/v69/i8/p874_s1?isAuthorized=no
Carnot cycle for photon gas?
Abstract only
“The Carnot cycle for a photon gas provides a useful means to illustrate the thermodynamic laws. It is particularly useful in showing the path dependence of thermodynamic functions. Thermodynamic relationships to a neutrino gas are also drawn.”
The following reference shows what happens if you mix a photon gas with a molecular gas. This probably applies to your model, since the universe does have both photons and molecules.
http://www.mdpi.org/lin/entropy/Paglietti-2009.pdf
“Thermal Radiation Effect in the Free Expansion of an Ideal
Gas and Gibbs’ Paradox in Classical Thermodynamics
The interaction with the thermal radiation that is contained within the volume of the body may be important in gases since the latter, unlike solids and liquids, are capable of undergoing conspicuous volume changes. Taking this interaction into account makes the behaviour of the ideal gases more realistic and removes Gibbs’ paradox.”
In reply to Dawin123
Talking about proportional responses. Nonetheless, I am going to point out that no pure classical mechanics can solve for a photon fluid, known as the ultraviolet catastrophe. A problem which was solved by Planck's law, which treated each electromagnetic mode as a quantum which may or may not contain a particle.
The law's of Thermodynamics, are none other than the observations that time goes forward and agitation dominates over relaxation. No quantum description is needed to realize the validity of these laws, however when investigating a new phenomenon which has been discovered by assistance of the quantum theory, one must at least find a resolution in the semi-classical, or pure quantum picture.
This isn't true. A quantum description is implicit in the validity of the Laws of Thermodynamics. You are confusing "historically classical" for "logically classical".
The four laws of thermodynamics are called classical physics, even though they aren't logically classical. As an example, this Physics Forum classifies the laws of thermodynamics as part of classical physics. Historically, this is correct because the laws of thermodynamics were deduced before Planck came up with the idea of energy quantization. However, this is incorrect from a logical and mathematical point of view.
The second and third laws of thermodynamics are inconsistent with classical mechanics. However, the second and third laws of thermodynamics are consistent with the laws of quantum mechanics.
The proof that the second law of thermodynamics is inconsistent with classical physics is referred to as Gibbs paradox. However, Gibbs paradox was resolved by deducing a third law of thermodynamics. I gave a reference on the Gibbs paradox in my previous post, which I won’t repeat here. It was only decades later that scientists realized that the third law of thermodynamics itself was inconsistent with classical mechanics.
It is now recognized that the third law of quantum mechanics is itself a consequence of quantum mechanics. Therefore, analysis using the four laws of “classical thermodynamics” brings into account quantum phenomena, whether or not quantum mechanics is explicitly used in the analysis.
The second law of thermodynamics when constrained by the third law is self consistent. The third law can be proven using quantum mechanics, using the principle that particles with identical quantum numbers are indistinguishable. Therefore, the second law of thermodynamics is consistent with quantum mechanics. Use of the third law of thermodynamics is implicitly including quantum phenomena in the analysis.
The third law of thermodynamics is implicitly nonclassical, meaning that it is invalid without quantum phenomena. So it is okay to use the classical laws of thermodynamics in a situation that where quantum phenomena are expected.
Here are a couple of links showing that the third law of quantum mechanics is itself consistent with quantum mechanics. The first two articles claim that the third law of quantum is invalid in a system that does not have quantum effects. Together with the Gibbs paradox, this leads to the conclusion that the second law of thermodynamics is not completely valid without quantum effects.
http://arxiv.org/abs/quant-ph/0601056
“The quantum thermodynamic behavior of small systems is investigated in presence of finite quantum dissipation. We consider the archetype cases of a damped harmonic oscillator and a free quantum Brownian particle. A main finding is that quantum dissipation helps to ensure the validity of the Third Law.”
http://physics.about.com/od/thermodynamics/a/lawthermo_5.htm
“Formulation 3 contains the least restraints, merely stating that entropy goes to a constant. In fact, this constant is zero entropy (as stated in formulation 2). However, due to quantum constraints on any physical system, it will collapse into its lowest quantum state but never be able to perfectly reduce to 0 entropy, therefore it is impossible to reduce a physical system to absolute zero in a finite number of steps (which yields us formulation 1).”
http://www.fh.huji.ac.il/~ronnie/Papers/PhysRevE.85.061126.pdf
Quantum refrigerators and the third law of thermodynamics
Amikam Levy,1 Robert Alicki,2,3 and Ronnie Kosloff1
PHYSICAL REVIEW E 85, 061126 (2012).http://arxiv.org/abs/0808.0229
“The optimal cycle is characterized by linear relations between the heat extracted from the cold bath, the energy level spacing of the working medium and the temperature. The scaling of the optimal cooling rate is found to be proportional to $T_c^{3/2}$ giving a dynamical interpretation to the third law of thermodynamics.”
http://arxiv.org/abs/quant-ph/0609159
“Does the Third Law of Thermodynamics hold in the Quantum Regime?
Here, we address the question raised in our title viz. Nernst's third law of thermodynamics.”
http://arxiv.org/abs/1109.0108
“Specific heat anomalies of small quantum systems subjected to finite baths”
“The system specific heat of $C_S(T)$ becomes $N_S k_B$ at $T \rightarrow \infty$ and vanishes at $T = 0$ in accordance with the third law of thermodynamics.” Maybe the Physics Forum should move thermodynamics into the Quantum Category, or even separate thermodynamics into its own category (Thermodynamics Category). However, that is not important to this discussion. What is important is that the second and third laws of thermodynamics have quantum mechanics folded into them.
What is the Thermodynamic Cosmic Problem?
The Thermodynamic Cosmic Problem is a paradox in physics that arises from the second law of thermodynamics, which states that the total entropy (or disorder) of a closed system will always increase over time. This contradicts the observed fact that the universe appears to be becoming more ordered over time.
How does the Thermodynamic Cosmic Problem relate to the universe?
The Thermodynamic Cosmic Problem is a fundamental issue in understanding the origins and evolution of the universe. It raises questions about the ultimate fate of the universe and the processes that have led to its current state of order.
What are some proposed solutions to the Thermodynamic Cosmic Problem?
There are several proposed solutions to the Thermodynamic Cosmic Problem. One is the idea of a "Big Crunch" in which the universe will eventually collapse back in on itself, resulting in a state of high entropy. Another is the concept of a "heat death" in which the universe will continue to expand and become increasingly disordered until all energy is evenly distributed and no further work can be done.
Are there any ongoing research efforts to address the Thermodynamic Cosmic Problem?
Yes, scientists are actively researching and proposing new theories to address the Thermodynamic Cosmic Problem. Some theories involve the concept of a multiverse, where our universe is just one of many, and others propose modifications to the laws of thermodynamics that could account for the observed increase in order in our universe.
What are the implications of solving the Thermodynamic Cosmic Problem?
Solving the Thermodynamic Cosmic Problem would have significant implications for our understanding of the universe and could potentially lead to breakthroughs in our understanding of the fundamental laws of physics. It could also provide insights into the fate of our universe and the possibility of other universes existing beyond our own.
  • Thermodynamics
  • Thermodynamics
  • Quantum Interpretations and Foundations
  • Thermodynamics
