Calculating Gas Temperature During Adiabatic Process with Fixed Piston
In summary, the problem involves a vertical cylindrical bottle with a fixed piston and an ideal 1-atomic gas with pressure P_1 in volume V_1 below the piston. The piston is then released and undergoes an adiabatic process with minimal friction. The task is to calculate the gas temperature at the moment of first stop of the piston. This can be done using a system of three equations (equation of state, energy conservation, and adiabatic process) with three variables. After some algebra, a single equation is obtained to determine T, but the solution is complex and requires further consideration of the kinetic energy of the piston.
elivil
Thermodynamics adiabat - help
Vertical cylindrical bottle is closed by a fixed piston (mass m). Under the piston in volume [itex]V_1[/itex] there is 1 mole of ideal 1-atomic gas with pressure [itex]P_1[/itex]. Over the piston there is vacuum, cross section area is equal to S. The piston becomes free and begins moving. There goes an adiabatic process. Friction between piston and walls of bottle is very small. Calculate gas temperature in the moment of first stop of the piston.
We have a system of three equations with three variables.
[tex] p(V_1+Sh)=RT [/tex]
[tex] mgh=c_v(T-T_1)[/tex]
[tex] p_1V_1^\frac {5} {3} = pV^ \frac {5} {3}[/tex]
First is equation of state, second is energy conservation, third - adiabatic process. h - difference in height of piston before moving and in the moment of first stop. [itex]T_1[/itex] is gas temperature in the beginning. [itex]c_v[/itex] - heat capacity in constant volume process (it's equal in this case to [itex]\frac {3} {2}R[/itex]).
After some algebra I got a single equation determining T:
[tex]T^3(aT+b)^2=c[/tex]
where a, b, c - constants equal to:
[tex]a=3RS[/tex]
[tex]b=(2mg-3p_1S)V_1[/tex]
[tex]c=T_1^3V_1^2m^2g^2[/tex]
It seems to me that this equation has one real solution but I can't find it.
Please help me.
Thank you.
You can write another equation addressing mechanical equilibrium.
EDIT: Also, I would write [tex] mgh=-c_v(T-T_1)[/tex] instead.
What mechanical equilibrium do you refer to? If you suggest something like
[itex]p_1S=mg[/itex], I don't think it's right because in the moment of first stop we don't have mechanical equilibrium. If it was the case then the first stop would be the final stop because nothing would force the piston to move again. My previous problem was just the same but I was obliged to find gas temperature after the final stop - it's quite simple and actually there is mechanical equilibrium.
Got it. Are you envisioning the piston gaining speed, passing the [itex]
p_1S=mg
[/itex] point, and decelerating due to gravity?
Yes, I think the piston will gain speed, then pass the equilibrium point but because it has a non-zero kinetic energy, it will continue to move after that point - so in fact it will be a nonlinear oscillation. The moment of first stop will be the moment when the piston turns around to move back to an equilibrium point after passing that point in the first time.
Wouldn't c be four times the value you have, from when you take care of [itex]\left(\frac{3}{2}R\right)^2[/itex]? Also, what do you think about the earlier comment about switching the sign? I can have Mathematica pick out the real solution.
Maybe, I've got wrong idea but I think I should reconsider energy conservation equation.
It seems to me that in the moment of first stop of the piston during its oscillations we should consider not only its potential energy but also its kinetic energy which has maximum at this point. Am I right? If yes, then it requires more change than just switching the sign (I agree with it).
Wouldn't the kinetic energy be zero when the piston comes to a stop? I think you were on the right track originally.
Incidentally, Mathematica can solve your equations but the real solution ends up being quite complex and many lines long.
1. What is thermodynamics adiabate?
Thermodynamics adiabate is a branch of thermodynamics that deals with systems undergoing changes without any heat transfer with their surroundings. Basically, it focuses on the relationship between temperature, pressure, volume, and energy in a system.
2. What is an adiabatic process?
An adiabatic process is a process in which there is no exchange of heat between the system and its surroundings. This means that the internal energy of the system remains constant, and the work done on the system is equal to the change in its internal energy.
3. What is the difference between adiabatic and isothermal processes?
An adiabatic process involves no heat transfer, while an isothermal process involves heat transfer at a constant temperature. In an adiabatic process, the change in internal energy is due to work done on or by the system, while in an isothermal process, the change in internal energy is due to heat transfer.
4. What is the first law of thermodynamics in adiabatic processes?
The first law of thermodynamics states that in an adiabatic process, the change in internal energy of a system is equal to the work done on or by the system. It is represented by the equation ΔU = W.
5. How is the adiabatic process represented on a thermodynamic diagram?
The adiabatic process is represented on a thermodynamic diagram as a curve that is steeper than an isothermal process. This is because the change in temperature is greater in an adiabatic process compared to an isothermal process, where the temperature remains constant.
