Temperature at junction of gold and silver bars?
In summary, the two blocks are insulated from all other directions - so ignore conduction to anything else. The problem statement meant to imply that the other end was maintained at 30 C. They didn't intend for you to be solving a transient heat transfer problem.
Feodalherren
605
A bar of gold (Au) is in thermal contact with a bar of
silver (Ag) of the same length and area (Fig. P20.39).
One end of the compound bar is maintained at 80.0°C,
and the opposite end is at 30.0°C. When the energy
transfer reaches steady state, what is the temperature at
the junction?
The figure just shows that the two blocks are insulated from all other directions - so ignore conduction to anything else.
P=kA(ΔT)/L
If one side is maintained at 80C wouldn't the whole system just keep warming up until it reaches 80C (steady state) then just conduct the same amount of heat that comes in from one side to the other side?
How does the system know that it's supposed to be 80 C and not 30C? If the would system reaches 80 C, how is the heat supposed to be conducted from one side to the other side with no temperature gradient present?
Let T be the temperature at the interface. What is the rate of heat conduction from the 80 C boundary to the interface? What is the rate of heat conduction from the interface at temperature T to the boundary at 30 C? What is the relationship between these two rates of heat conduction at steady state?
Chet
Likes 1 person
See that's what throws me off. The problem says that one side is maintained at 80C, it says nothing about the other side being maintained. If one side is maintained and the other is not, doesn't the whole system go to equilibrium at whatever temperature is maintained at one side? So once both the Ag and Au are at 80C it conducts heat to the 30C side and keeps doing that until it also goes to 80C.
If I have a metal rod and I keep it on a flame the metal rod will eventually become as hot as the fire (ignoring any other sources of conduction, radiation or convection).
But going with what you said I'd do something like this
[itex]K_{Au}A\frac{T-80}{L} = K_{Ag}A\frac{T-30}{L}[/itex]
This result is correct (except for a sign error), and is all that they were looking for.
Chet
It's 80-T on the left and T-30 on the right but otherwise that equation is correct :D
What is thermal conduction?
Thermal conduction is the transfer of heat through a solid material or between two materials that are in direct contact. It occurs when there is a difference in temperature between two objects, causing the hotter object to transfer heat to the colder object until they reach thermal equilibrium.
How does thermal conduction work?
Thermal conduction works through the transfer of energy between particles in a material. When one particle is heated, it begins to vibrate more rapidly, colliding with neighboring particles and transferring some of its energy to them. This process continues, causing the heat to spread through the material.
What factors affect thermal conduction?
The rate of thermal conduction is affected by several factors, including the temperature difference between the two objects, the type of material, the distance between the objects, and the surface area of contact between them. Materials with higher thermal conductivity, such as metals, will transfer heat more quickly than materials with lower thermal conductivity, such as wood or plastic.
What are some real-world applications of thermal conduction?
Thermal conduction is used in many everyday applications, such as cooking, heating and cooling systems, and even in thermal imaging cameras. It is also an essential concept in engineering and thermodynamics, as it helps us understand how heat is transferred in various systems.
What are some ways to reduce thermal conduction?
In order to reduce thermal conduction, materials with lower thermal conductivity can be used, such as insulating materials. Increasing the distance between two objects can also decrease the rate of thermal conduction. Additionally, reflective surfaces and air gaps can help to reduce the transfer of heat through conduction.
9K
  • Atomic and Condensed Matter
