• Support PF! Buy your school textbooks, materials and every day products Here!
Thermodynamics Demonstration
  • Thread starter The28
Main Question or Discussion Point
So I need to give an exciting thermodynamics demo based on one of the first two laws. I have found it difficult to either make it exciting enough or to make it apply to thermodynamics enough.
I have a few that I have come up with but I don't think any really apply as well as I want.
1)Can crush but on a bigger scale with like a drum. Heat water in a can and then dunk it in cold water. (shows that heat flows from hot to cold 2nd law)
2)Spud gun. Giant spud gun but thats see through. Ignite gas and fire potato (Add heat and show that work is done on the potato 1st law)
3)Boiling water and liquid nitrogen. Nitrogen evaporates and makes a huge cloud due to condensing water from the air (2nd Law showing that heat again flows from hot to cold and energy is dissipated)
Are any of these any good?
Could do with some help.
Answers and Replies
jfizzix
Insights Author
354
Depending on your budget, you could get one of those coffee cup Stirling engines. Last time I checked, you can find a nice one for less than 100 bucks. They run off the temperature difference between the hot coffee and the comparatively low temperature surroundings. Also, you can make the engine run faster by putting an ice cube on top of it (i.e., by increasing the hot-cold temperature difference).
If you have a vacuum pump, you can freeze liquid nitrogen, or just freeze water through evaporative cooling. With the vacuum pump, the most energetic molecules will escape the liquid and be pumped out, lowering the average internal energy of the liquid, cooling it down, until it freezes.
Related Threads on Thermodynamics Demonstration
  • Last Post
