Thermodynamics entropy problem
Find (a) the energy absorbed as heat and (b) the change in entropy of a 2.00 kg block of copper whose
temperature is increased reversibly from 25°C to 100°C. The specific heat of copper is 386 J/kg K .
dS=dQ/T
dS=nRln(final volume/initial volume) **for an ideal gas**
Well I got the first part. The energy is just
dQ=cmdT
which is (386)(2)(75K)= 57900J
however, when i got to the second part, I didn't know what to do since the copper isn't an ideal gas, and it has a non-constant temperature so I can't use the first equation. Any help would be appreciated!!!
Answers and Replies
Entropy Thermodynamics problem
dS=dQ/T
dS=nr ln(vf/vi) **for an ideal gas**
The first part was relatively easy. I just used the equation:
dQ=cmdT
so, dQ=(386)(2)(75)=57900 J
But for the 2nd part, I dont know what to do because copper is not an ideal gas, ruling out the 2nd equation, and the temperature is not constant, meaning I cannot use the first equation. Any help would be great!!!
dS = dQ/T
dQ = cmdT
dS = cmdT/T
Integrate both sides to get delta(S) = cm*ln(Tf/Ti); be sure to use Kelvin.
Its been a while since I've done thermodynamics, so I might be wrong...though I only applied a bit of mathematical procedure, so it seems as though it would be fine.
sounds right to me.... thanks for the help!
Related Threads on Thermodynamics entropy problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
